Technical Forum
intelligent load balancing issue
Jahmedj
I have an https client connections on F5 LB. All client traffic uses default https port 443. the VIP should forward the traffic to a different ports in same pool of two server. The idea is request from https://jahmedj.com/abc must go to server1 on port 7901 and https://jahmedj.com/xyz must go to another server on port 7902.
i craeted policy and applied but not working, looking for alternate method to achive this LB.
6 REPLIES 6
dear Vaibhav,
I will try and and update you.
Dear Vaibhav,
No, it didn't work.
All traffic perhaps going to forst pool only.
any other clue
@Jahmedj, following up on my comment below, you can use a Local Traffic Policy.  I have a setup where any uri-path equal to /abc or starting with /abc/ goes to a pool using port 8080.  Any uri-path equal to /xyz or startin with /xzy/ goes to a pool using port 8081.  The node (server) set in each pool is the same.  Here are the relevant snippets:
ltm virtual vs-http-01 {
    destination 10.1.10.100:http
    policies {
        pool-steer-by-uri-path { }
    pool pool-8080
    profiles {
        f5-tcp-progressive { }
        http { }
    source-address-translation {
        type automap
    translate-address enabled
    translate-port enabled
    vlans {
        clients
    vlans-enabled
ltm pool pool-8080 {
    members {
        server01:webcache {
            address 10.1.20.20
            session monitor-enabled
            state up
    monitor http
ltm pool pool-8081 {
    members {
        server01:tproxy {
            address 10.1.20.20
            state up
    monitor http
ltm policy pool-steer-by-uri-path {
    controls { forwarding }
    requires { http }
    rules {
        "uri path abc exact" {
            actions {
                0 {
                    forward
                    select
                    pool pool-8080
            conditions {
                0 {
                    http-uri
                    path
                    values { /abc }
        "uri path abc starts_with" {
            actions {
                0 {
                    forward
                    select
                    pool pool-8080
            conditions {
                0 {
                    http-uri
                    path
                    starts-with
                    values { /abc/ }
            ordinal 1
        "uri path xyz exact" {
            actions {
                0 {
                    forward
                    select
                    pool pool-8081
            conditions {
                0 {
                    http-uri
                    path
                    values { /xyz }
            ordinal 2
        "uri path xyz starts_with" {
            actions {
                0 {
                    forward
                    select
                    pool pool-8081
            conditions {
                0 {
                    http-uri
                    path
                    starts-with
                    values { /xyz/ }
            ordinal 3
    strategy first-match
This particular code does not strip the leading part of the URI path.  Thus, if one goes to:
http://10.1.10.100/abc/def/file.html
then that is the same path (i.e., /abc/def/file.html) that would be sent to server01 port 8080, rather than, say, /def/file.html.  The latter is possible, as well, if desired.
VernonWells
F5 Employee
F5 Employee
@Jahmedj, the subtlety in the link that @vaibhav provided is that there are two pools.  In general, a "node" on a BIG-IP corresponds to a target IP address of a forwarding target.  A "pool member" is the combination of a "node" and a layer4 port.  A "pool" consists of a collection of zero or more "pool members".  The two pools would have members that have the same node IPs, but different ports, as in:
ltm node server01 { address 10.10.1.5 }
ltm node server02 { address 10.10.1.6 }
ltm pool target_7901 {
   members { server01:7901 server02:7901 }
ltm pool target_7902 {
   members { server01:7902 server02:7902 }
Your Local Traffic Policy would then target the corresponding pool based on the URI path match.
vaibhav
Have a look at this one and let me know what out of this doesnt work for you and we can modify this,  I tested this one below and it works. Ignore the wildcard as thats not your case
And what modifications are needed ... i am yet to explore policies equivalent of I-rule but i can try modifying the Irule
ltm rule pool_URI-redirection {
switch -glob [HTTP::uri] {
"/URI1/v1.0/RMAOrders*" {
pool pool_pool_5101
"/URI1/v1.0/miscIssues*" {
pool pool_pool_5085
"/URI1/v1.0/miscReceipts*" {
pool pool_pool_5084
"/URI1/v1.0/pickReleaseOrdersAck*" {
pool pool_pool_5083
"/URI1/v1.0/poReceipt*" {
pool pool_pool_5081
"/URI1/v1.0/purchaseOrdersAck*" {
pool pool_pool_5079
"/URI1/v1.0/purchaseOrders*" {
pool pool_pool_5078
"/URI1/v1.0/RMAReceipts*" {
pool pool_pool_5111
"/URI1/v1.0/shipConfirmOrders*" {
pool pool_pool_5076
"/URI1/v1.0/subInvTransfers*" {
pool pool_pool_5077
"/URI1/v1.0/pickReleaseOrders*" {
pool pool_pool_5082
"/anotherURI/Endpoint*" {
pool pool_pool_5115
