Ruben_79895
Altostratus
Dec 09, 2008Input drops on interface
Hello,
I have a lot of input drops in every interface connecting to my Cisco Catalyst 3550 and the counters is incrementing constantly. I have checked the switch and there aren't any errors. Also I have checked the cabling and it is ok.
This is happening in my lab environment. Is there any special type of packet that the BIG IP always drops by default? Is there any way to know which packets are being dropped? Any advice?
Thanks in advance,
- zeng_song_63481
maybe you should check the work mode of the interface on both F5 and Cisco - Ruben_79895
Altostratus
Hello,
both sides are working in "auto". Maybe is better to hardcode the speed&duplex?
Regards,
Ruben
