Technical Forum
IMAP/POP3 forwarding to specific pools
Jizbel
Hi, I am new to irule and I am looking for some feedback or help with regards to an issue. I have two domains, going through an f5 vip, to the same email server pool to look for email. So both user@abc.com and user@def.com is currently loging into email server pool 1. I am planning to have a separate email server pool for each domain. So @abc.com goes to server pool 1 and @def.com goes to server pool 2. Is there a way f5 can log the user login domain and route the traffic to the respective pool?
Any help appreciated. Thanks
2 REPLIES 2
There have been other posts for similar issues where "TCP::collect" is used to collect the payload and then matching it you can select a pool.
https://clouddocs.f5.com/api/irules/TCP__collect.html
https://community.f5.com/t5/technical-forum/irule-to-log-pop3-imap-user/td-p/166572
LiefZimmerman
Community Manager
Community Manager
@Jizbel - If your post was solved it would be helpful to the community if you selected *Accept As Solution* on the relevant reply (or replies). This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
