sandy16's avatar
sandy16
Jun 20, 2016
illegal cookie length: ASM violation
HI ASM experts, I am seeing traffic getting blocked due to the "Illegal cookie length violation" . System configured: 8192 bytes, received 8452. I am running 11.5.1 HF7. I tried to increase the cookie length by going to the policy and selecting advanced, BUT it gave me an error that the max allowed is 8192 bytes. What is the work around for this? This seems to be a legit GET request.
  • Hi,
    8192 bytes is the default length, not the max allowed in general.
    I will try it on my lab and give you a feedback
    • Yann_Desmarest's avatar
      Yann_Desmarest
      Icon for Cirrus rankCirrus
      In fact, that's true. 8192 bytes is the maximum length you can define for header and cookies. This is a limit that include name+value. You can change this setting by Any if you have headers that exceed this max length
  • Hi,
    • Yann_Desmarest_'s avatar
      Yann_Desmarest_
  • 8192 Is indeed the maximum and I think you only have 2 workarounds - disable the violation, or write a custom iRule. Disabling the violation itself would probably make the most sense here.
    Go to policy blocking settings, and un-tick the 'learn/alarm/block' boxes under
    violation. Save and apply changes.
    • MSZ's avatar
      MSZ
      What about 2048 bytes
    • MSZ's avatar
      MSZ
      when I created the ASM policy longtime back I didn't notice the value of Max. cookie header length (It comes on Policy properties page). As per documentation it is any by default. But in my case I am able to see the value like 2048. I want to know how this value comes and where ?
    • MSZ's avatar
      MSZ
    • MSZ's avatar
      MSZ
