networksecurity2022's avatar
Mar 31, 2022
i rule
please help me to create Irule below requirement.
If <sourec ip1 >or <source ip2> IPs are the sourceAddress and Host header is either <x.x.x.x>or <Y.Y.Y.Y> then you have to allow the communication. Other than <sourec ip1 > and <source ip2> IPs, rest of the IPs will be blocked if they are having IP in the host header.
  • Hello networksecurity2022.
    Try this
      if { ([IP::client_addr] eq "<sourec ip1>") || ([IP::client_addr] eq "<sourec ip2>") } {
        if { !(([HTTP::host] eq "<x.x.x.x>") || ([HTTP::host] eq "<y.y.y.y>")) } {
          reject
  • Above rule not working,  request must allow. only reject Other than source ips, rest of the IPs will be blocked if they are having IP in the host header.
    • Dario_Garrido's avatar
      Dario_Garrido
      Icon for Noctilucent rankNoctilucent
      Hello.
      Check this one.
      Rejects everything to those IPs (<x.x.x.x> or <y.y.y.y>) in the host header, except if the source is one of those IPs (<source ip1> or <source ip2>)
        if { ([HTTP::host] eq "<x.x.x.x>") || ([HTTP::host] eq "<y.y.y.y>") } {
          if { !(([IP::client_addr] eq "<sourec ip1>") || ([IP::client_addr] eq "<sourec ip2>")) } {
            reject
