IRONMAN
Aug 19, 2019Cirrostratus
Solved
i Have LTM Connected directly with Core Switch with two interfaces?
I am facing small design challenge, i Have LTM & AFM Connected directly with Core Switch with two interfaces, each are different purpose?
Interface one for incoming traffic from client side?
Interface two for outgoing to traffic to Server Farm?
How to achieve this? Because I am using IP forward Virtual servers with AFM , Which Ips are same as server farm? I don,t want traffic from core should go directly server without LTM and AFM inspection?
Hi Saravanan,
On your core switch, there should be no SVI/VRF for the vlan of the Server Farm. This will break your configuration. Your setup will only work if your server vlan is a L2 vlan on the core switch.
Cheers,
Kees
