lizunjjg_280139's avatar
lizunjjg_280139
Jul 11, 2018
i have client ssl off_load question
hi guys 1. client ssl off_load VIP is on port 443 and pool members also in service port 443 . 2. pool members can not change port (also 443 ) They want to do ssl offload on the VIP will it work???
  • Providing you have an HTTP profile and a client-ssl profile it will work as F5 is a full TCP proxy. Having both the virtual server and pool members on the same port will not affect the connectivity and the ability off load SSL.
  • Hi,
    Your server backend listen in https too?
    in this case it's not ssl ofload but interception and you need ssl client and ssl server profile.
    regards
  • hi The server only use port 443. server side do not encryption.
