Technical Forum
HTTPS virtual server with custom TCP port
Mohammed_Moin_2
Hi, How to configure a HTTPS virtual server with custom TCP port Example: https://abc.com:8872
3 REPLIES 3
Snl
Please try below and let us know how it goes
1) Create SSL Client profile with allowing Non-SSL Connections ( You need to modify default config)
2) Create VIP with 8872 port and use SSL client profile
3) Configure below iRule
if { [URI::protocol [HTTP::uri]] eq "http" } {
HTTP::redirect https://[getfield [HTTP::host] ":" 1]:[TCP::local_port][HTTP::uri] }
Kevin_Stewart
F5 Employee
F5 Employee
I think Mohammed.Moin is maybe just asking how to create an HTTPS VIP on a custom (not port 443) VIP.
If that's the case, there's nothing you really need to do differently, other than simply changing the listening port in the VIP configuration. Just change it from 443 to 8872.
Would that require a HTTP profile? I noticied that if I apply a http profile, the VIP failes to open
ex:
1) https://test.com:8872 with http profile,no ssl client and no ssl server profiles does not open and shows error "This site can't be reached"
2) https://test.com:8872 with no http profile,no ssl client and no ssl server profiles opens as "notsecure"
When we would need http profile? Would we need it only if we have client ssl and server ssl profiles?
