28-Nov-2019 14:47
Please help me to create an irule or policy to redirect https://loadandgo.test.ca to https://www.test.ca/arrow/Redirect?id=45156_Rexall_LoadandGo_E. I'm not sure what service port should I use since I already tried different options and none of them did work. Whenever I try to load https://loadandgo.test.ca none of the rules worked nor policy I created. it only works when I use service port 80 and load http not https(which I need) in this case. Irules used so far:
if { [string tolower [HTTP::host]] eq "www.example.com" and [HTTP::path] eq "/path1/abc" } {
HTTP::respond 301 Location "http://www.new-example.com/abcd"
1. if { [HTTP::host] eq "website1.com" } {
2. HTTP::redirect https://websitesite2.com[HTTP::uri]
3. }
1. when HTTP_REQUEST {
2. if { ([string tolower [HTTP::host]] equals "page1.com") && ([TCP::local_port] == 443)} {
3. HTTP::redirect "http://page2.com"
4. }
5. }
2. if { ([string tolower [HTTP::host]] equals " page1.com") && ([TCP::local_port] == 443)} {
3. HTTP::redirect " http://page2.com"
4. }
28-Nov-2019 19:55
Help us confirm few things, Is https://loadandgo.test.ca managed in your LTM.
If yes, I believe you have an 80 Virtual & a 443 virtual. I could see 80 virtual is already redirecting it to 443 already.
Help us understand the 443 virtual configuration. Are you simply putting an Irule to do the redirection to your another url (BTW, I see you have missed to mask your domain, mask it if you feel its confidential).
Note 443 virtual is https. Its an encrypted tunnel. You can't do redirection stuffs unless you see make it a plain text. So offload the SSL traffic first with a clientssl profile. And then do your Irule stuff.
Let us know how it goes.
29-Nov-2019 09:04
I did with the right clientSSL and Irule applied to it. The Irule i used worked for me:
4. }
Thanks again for your help. I masked the domain name BTW.
30-Nov-2019 04:47
Good to hear that the issue is solved. You can mark your own as solved then.
13-Jun-2023 08:19
need help to provide irule or policy redirect https url to another https URL
https://abc.com /Default.aspx should be redirected to https://xyz.com
Pls help
