Technical Forum
HTTPS to HTTP
kashif_shahzad
hi,
i have a situation where i have to redirect incoming traffic on https to http as the old applications does not support https yet.
i have tried to create 2 VS one http and one https and tried to use en IRULE to redirect traffic to http under https VS. but it fails with " The provided URI scheme 'https' is invalid; expected 'http'. (Parameter 'via') " message.
i have tried it with policy also by forwarding traffic to http VS but still same message.
irule that i tried was as under. tried with redirect also.
HTTP::respond 301 Location "http://[HTTP::host][HTTP::uri]"
has anybody been in this kind of situation and managed to get things working....?
1 ACCEPTED SOLUTION
Hi @kashif_shahzad ,
> Create a https virtual servers and do not assign any pool to it.
> use this iRule inside the Https virtual server.
       HTTP::redirect http://[getfield [HTTP::host] ":" 1][HTTP::uri]
> Create another Http (port 80) virtual server and assign the required pool to it.
> Browse your https://url , and track your redirection.
it works with me
Look at these snap shots :
Regards
_______________________
Regards
Mohamed Kansoh
1 REPLY 1
it works with me
Regards
Regards
Mohamed Kansoh
