15-Mar-2022 09:19
Hi All,
I am trying to create a new HTTPS health Monitor for pool which contains Cisco ISE.
For testing I am using below cURL string, and it is given below output:
curl -u username -k --location --request PUT ‘’https://ISE-Server/Url' --header 'Accept: application/snd.com.cisco.ise.identity.guestuser.2.0+xml' --header 'Content-Type: application/xml'
Curl Output:
<?xml version="1.0" encoding="utf-8" standalone="yes"?><ns3:ersResponse operation="PUT-suspendByName-guestuser" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ns3="sss.ise.cisco.com"><link rel="related" href=" https://ISE-Server/Url" type="application/xml"/><messages><message type="ERROR" code="CRUD operation exception"><title>Suspend request for GuestUser By name (username) failed due to The GuestUser name (username), not found.</title></message></messages></ns3:ersResponse>
This is the desired output as per Engineer.
Now I am trying to convert this to HTTPs monitor as per below:
Send String:
PUT /Url HTTP/1.1\r\nHost: <host>\r\nContent-Type: application/xml\r\nConnection: Close\r\n\r\n
Receiver String:
<title>Suspend request for GuestUser By name (apitest) failed due to The GuestUser name (apitest), not found.</title>
But Pool member is showing Down.
Can someone pls support me to create a proper send and receive string for this. It seems I am not properly using Content-Type & Accept header in receive string.
24-Mar-2022 05:55
Hello Deepak.
I guess your response is not matching the receive string properly. Just try it from a small string, maybe something like "GuestUser" and check if it matches.
13-Apr-2022 02:24
@Deepak_Kumar2 - Check if your need useragent header as mentioned in https://support.f5.com/csp/article/K65151034. Check if you are using username apitest in the monitor. Enable monitor logging under pool member and you can check the logs.
I would suggest, refer to standard Cisco ISR deployment guide with F5 and use the monitor mentioned there. I don't see PUT monitor is mentioned in the doc.
