Technical Forum
HTTPS Monitor: receive string with quotation mark
kgaigl
Hello,
I need to create a HTTPS Monitor to a status page of the application, the answer is like this:
portalStatus:	"AVAILABLE"
(I get this answer from a browser)
when I set the receive string to portalStatus:"AVAILABLE" the Monitor doesn't get the string.
Do I have to use some brackets or backslashes?
could someone help me with this?
1 ACCEPTED SOLUTION
kgaigl
ok, got it:
\"portalStatus\":\"AVAILABLE\"
works
3 REPLIES 3
kgaigl
additional info:
the monitored address is a json-file, any tipps for this?
kgaigl
ok, got it:
works
Lidev
MVP
MVP
Hi Kgaigl,
Please mark your answer as "Select as Best" in order to pass your post as resolved and help other people to find it 😉 Thanks
