Oliver_Schmidt's avatar
Oliver_Schmidt
Feb 14, 2006
http keep alive tmeout between bigip and client
I want to define a keep alive timeout for the client - bigip connection. In an http profile you can only configure the max. no. of connections. The keep alive timeout in an oneconnect profile defines the timeout for the bigip - webserver connections. Without this timeout the bigip waits for the tcp timeout to reset the connection. The keep alive timeout of the webbrowsers is although to big.
Any ideas?
Oliver
  • You might want to move this over to the iRules forum. iControl is our management API and I don't see how it applies to this question.
    -Joe
