karthik_sriniva's avatar
karthik_sriniva
Apr 11, 2005
HTTP Header
I have to change the HTTP header authorization to include different username and password from the one that was received by BigIp for authentication.
If I add the following line of code in the "when AUTH_SUCCESS" event, I get compile-time error
HTTP::header insert Authorization "Basic: 123455:12345"
Is there a way to execute the above line of code, after the when AUTH_SUCCESS code is executed and before the request is sent to the back-end application server for processing.
  • Tao_Liu_90341's avatar
    Tao_Liu_90341
    Historic F5 Account
    There is constraint that some HTTP:: cmds can't be executed under AUTH events. You can work around by replacing the header in HTTP_REQUEST after you have extracted AUTH username/password.
