I have URL xyz.abc.com now when client hits this URL ..F5 should insert http header with server name ,which server request should be forwarded .
do you want to manually select server and insert custom http header based on hostname in url (host header)?
or
do you want to rewrite http host header based on load balanced server?
this is an example of the latter one.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 7
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
200.200.200.101:80 {
address 200.200.200.101
200.200.200.111:80 {
address 200.200.200.111
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm data-group internal servername
ltm data-group internal servername {
records {
200.200.200.101/32 {
data server101
200.200.200.111/32 {
data server111
type ip
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
when HTTP_REQUEST_SEND {
clientside {
HTTP::header replace Host [class lookup [LB::server addr] servername]
trace
[root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.24.1(38986) - 172.28.24.10(80)
1409877091.1710 (0.0015) C>S
GET /attempt1 HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: 172.28.24.10
Accept: */*
New TCP connection 2: 200.200.200.14(38986) - 200.200.200.111(80)
1409877091.5871 (0.4142) C>S
Host: server111
Accept: */*
