09-Mar-2021 18:40
Hello Experts ,
I am trying to build an irule which will send a HTTP 404 error CODE if the user intentionally or mistakenly typed a wrong URL .
Below is the IRULE that i have written :
if {([string tolower [HTTP::host]] equals "xyz.APAC.com") && [HTTP::uri] starts_with "/ARCHIAC" } {
HTTP::uri [string map [list "/archiac/" "/arcgis/" ] [HTTP::uri]]
pool PL_BNE_ENT_6443
return
if {([string tolower [HTTP::host]] equals "xyz.APAC.com") && [HTTP::uri] starts_with "/archiacportal" } {
pool PL_BNE_ENT_arcgisportal_443
return
if {[HTTP::uri] matches_regex ".*" } {
HTTP::respond 404 content {Page Not Found Page Not Found}
This irule work fine for most of the cases . BUT if any user start the URI with /ARCHIACjkaejksfsdjkhdfsj , this request will be send to server .
Same is TRUE with /archiacportalsdfjkbasdjkfbsd .
If there any way to discard the junk characters with HTTP 404 error when someone start the URI with above STRINGS ???
10-Mar-2021 12:04
/ARCHIACjkaejksfsdjkhdfsj matches your first starts_with condition. Can you give a couple more examples of good matches versus bad matches? I'm not sure I have a clear enough picture of what is "good" to provide you a proper solution. On top of that, a few comments:
12-Mar-2021 20:08
Hi Jason Rahm ,
I have re-written my irule using some variable for flexible matching :
Here is irule that i am using :
set host [string tolower [HTTP::host]]
set uri [HTTP::uri]
if {$host equals "xyz.apac.com."} {
set context [getfield $uri "/" 2]
if {($context ne "archiacserver") and ($context ne "archiacportal") and ($context ne "archiac")} {
} elseif { ($uri starts_with "/archiacserver")} {
HTTP::uri [string map {"/archiacserver" "/archiac"} [HTTP::uri]
HTTP::redirect "https://$host[HTTP::uri]"
return
} elseif {$uri starts_with "/archiac"} {
}elseif {$uri starts_with "/archiacportal"} {
pool PL_BNE_ENT_archiacportal_443
return
SO below are GOOD matching :
www.xyz.apac.com/archiacserver
www.xyz.apac.com/archiacserver/
www.xyz.apac.com/archiacserver/abcde/efgh
www.xyz.apac.com/archiacportal
BAD MATCH
www.xyz.apac.com/dhghasgharchiacserver
www.xyz.apac.com/ARCHIACSERVER
www.xyz.apac.com/archiacserveradjefjaehfje
www.xyz.apac.com/archiacserver)*)*)*)*)*)
www.xyz.apac.com/archiacPORTAL
www.xyz.apac.com/ARCCHIACPORTALjdfbjdsfjasd
etc etc
SO my code work fine with testing and loading the APP through LB and also now looks like error handling works fine . . But i am seeing some issues with session kick out .
For example if i try to load www.xyz.apac.com/archiacserver/admin/login , this works fine .Page load up with username and password and work perfectly .
But if i hover to some tab after logged in and click , the session times out and ask for a re-login .
we are not doing any Load balancing , simply sending the traffic to pool and my pool is configured with ACTIVE/STANDBY nodes using priority group .< 1 with one node being on 10 and other on 5 .
So no cookie persistence needed .
ANy suggestions ?? something wrong with my irule ?
No session kick out when i hit the node directly .
15-Mar-2021 09:31
If you are trying to match the path and NOT the query parameters, you'd be better off using HTTP::path, which only includes path information for that instead of HTTP::uri, which includes both path and query parameters.
For your badmatch, are you saying those are still matching, or that they are no longer matching?
finally, are you seeing any tcl errors in the logs when the sessions are being "kicked out"?
FYI, I'm going to be out on PTO for the next few days
17-Mar-2021 21:04
Hi Jason ,
Thanks for writing me back .
The bad matches are no longer matching .This is the irule I am using as POC :
set uri [HTTP::uri]
return
return
Regarding the error , I found I need to set x-forwarded for host with the HTTP profile and also at the server end they need to set a web context URL for re-write .
The issue is now fixed . Thanks !
18-Mar-2021 11:44
good deal!
