Technical Forum
How to use literals starting with "$" in iRule
Genna_Reingold
I need to pass client certificate to WebSphere so the application can perform SSL based authentication. I following this article https://support.f5.com/csp/article/K95338243
However in WebSphere App Server the headed for client certificate is $WSCC. But if I code iRule like this
  HTTP::header insert $WSCC [b64encode [SSL::cert 0]]
$WSCC is treated as a variable WCSS and the rule is broken
How do I get around this issue?
Genna
2 REPLIES 2
Daniel_Wolf
Nacreous
Nacreous
Hi Genna,
you can escape the '$' character with a '\'. This should work:
    HTTP::header insert "\$WSSC" [b64encode [SSL::cert 0]]
KR
Daniel
Stan_PIRON_F5
F5 Employee
F5 Employee
to prevent variable substitution, you can replace double quotes by curly braces.
    HTTP::header insert {$WSSC} [b64encode [SSL::cert 0]]
Stan
