- FFEmployee
You can actually use the inventory export on the BIG-IP devices page in the BIG-IQ system interface which produces a CSV file. The managed BIG-IP device's serial number as well as registration key can be found in that CSV file. This includes VIPRION chassis serial number as well as the installed blade's serial number. Additionally, the BIG-IQ system interface reports the serial numbers of VIPRION installed blades on the property page of the managed VIPRION device. For more information, you can check out https://support.f5.com/csp/article/K32548743
- Nathan_F__F5_Employee
Hi AJF5,
I wasn't able to find anywhere in the GUI that displays the serial number of each of the managed BIG-IP devices in BIG-IQ. The only thing I was able to find was the "Export Inventory" button under Devices >> BIG-IP Devices in the GUI. That will generate a spreadsheet with all of the information for each of the managed devices. I should also note that I found this on v7.0.0.1 of BIG-IQ so it's possible that it might be located in a slightly different place in the GUI if you are running an older software version.
I hope this helps.
-Nathan F
