21-Sep-2016 04:44
I want to limit magager ports ,I found manager port can't through port Lockdown ,also can't through packet filter . Do you have other ideas ?
Solved! Go to Solution.
21-Sep-2016 05:26
The MGMT port should only be attached to a Secure Management network, its kind of by design.
You should ideally lock it down with Firewall rules on an adjacent device, VLAN segregation etc.
21-Sep-2016 05:26
22-Sep-2016 00:57
Presuming that you wish to restrict access by netblock, you can restrict ssh access on the management interface:
and separately do the same for TMUI (the Web UI):
22-Sep-2016 05:14
3Q
22-Sep-2016 00:57
22-Sep-2016 05:14
3Q
