Amandeep_Singh's avatar
Amandeep_Singh
Feb 01, 2021
How to configure SMTP settings on F5 15.x for sending out email notifications?
How can we set up the SMTP on f5 running 15.x software version?
I have the following config in place:
(tmos)# list sys outbound-smtp
sys outbound-smtp {
  from-line-override disabled
  mailhub smtp.gmail.com:587
  rewrite-domain bigip1.f5lab.com
I have also modified the user_alert.conf file and added many scripts for sending an email for pool members going down/SSL cert expiration etc. But nothing is working.
Thanks in advance!
  • Hello Amandeep.
    outbound-smtp section is still pending to support Authentication and TLS.
    https://support.f5.com/csp/article/K87630102
    To workaround this, you can still use the configuration file /etc/ssmtp/ssmtp.conf, but take into account that this config will be removed after every reboot.
    https://support.f5.com/csp/article/K13180
    Regards,
    Dario.
    • Stefan_Klotz's avatar
      Stefan_Klotz
      Regarding reboot- and software update safe, is the standard tmsh configuration for outbound-smtp persistend?
      Thank you!
      Regards Stefan 🙂
