Sort By
- what does bind mean in this context? do you want to see http://cloud/dns in your address bar while browsing https://dlwiki.test.com/wiki/index.php/DNS ? is this meant for internal only or do you expect this to work on the internet also? why the change from https to http?
- Parveez_70209Nimbostratus
Yes for Internal purpose only.
Can we redirect something using PHP script too ?
Kindly suggest.
How can we see http://cloud/dns in our address bar while browsing https://dlwiki.test.com/wiki/index.php/DNS.
For Internal users only. Is is possible using uri::path syntax ?
Thanks and Regards Parveez
