Sort By
- nitass_89166Noctilucent
check 0x0ff.info's reply.
TCP monitor with sending a byte sequence
- Amit585731Nimbostratusso as per forum if I want to put a value in send string so it will be something like this? \x02 \x41 \x42 \x00 correct? or do I need to define any get command etc...
- nitassEmployee
