Technical Forum
How I configure syslog included specific string at /var/log/ltm ?
Jiwook
here is our syslog configuration
sys syslog {
auth-priv-from notice
auth-priv-to emerg
clustered-host-slot enabled
clustered-message-slot disabled
console-log enabled
cron-from warning
cron-to emerg
daemon-from notice
daemon-to emerg
description none
include none
iso-date disabled
kern-from debug
kern-to emerg
local6-from notice
local6-to emerg
mail-from notice
mail-to emerg
messages-from notice
messages-to warning
remote-servers {
remotesyslog1 {
description none
host X.X.X.X
local-ip X.X.X.X
remote-port 514
user-log-from notice
user-log-to emerg
And i want configure syslog to include specific string on /var/log/ltm
how I can do this plz help me
13 REPLIES 13
The point is not how configure syslog, the point is configure syslog to include specific string on /var/log/ltm.
You are exactly right
you should follow the guide that I share with you, it looks probably to help you with your requirement, if not, share what string do you want exactly to add.
Actually, I want to include expired Ssl certification log on /var/log/ltm to syslog. I try to test some solutions on devcentral, but there are many of different suggestions and make me confused 😞
I need to filter and include some log lines contained string 'expire' to syslog
Ok, but it looks easy, there are native configurations that you can apply to meet your requirement:
This is one on the crontab daemon executed every day:
https://support.f5.com/csp/article/K14318
You can send alert by email, or monitor by SNMP the F5:
https://support.f5.com/csp/article/K15288
You can be create a filter to matches a specific message-id and transmits it to the local-syslog log publisher.
From the CLI enter following commands:
tmsh create /sys log-config publisher local-syslog destinations add { local-syslog }
tmsh create /sys log-config filter filter_cert_will_expire message-id 01420008 publisher local-syslog
tmsh create /sys log-config filter filter_cert_expired message-id 01420007 publisher local-syslog
Hi @Jiwook ,
In that case, you could check this article which discusses the built-in SSL certificate expiration monitoring. The check-cert utility runs weekly and does create log messages regarding the certificates. I checked in my own environment and did see the messages get logged to syslog.
K14318: Monitoring SSL certificate expiration on the BIG-IP system (11.x - 16.x)
The messages would look similar to this:
01420008:4: Certificate 'CN=host.example.com' in file /Common/host.example.com.crt will expire on Mar 20 23:59:59 2022 GMT
Thanks,
Josh
Same Article that I shared before.
Please use caution with older guides. The guide you mentioned uses "bigpipe" or b shell commands, which were deprecated some time ago and won't work in recent versions.
@Sebastiansierra my apologies, I did not notice that you had pasted the same article previously.
Jiwook
Thanks for all your helps.
Im deeply moved by your passion to save me.
I will test your suggestions tomorrow, and let you know about the results.
It is 2:08 am here and i should go sleep now..
Thanks anyway for real and have a nice day all of you 🙂
