21-Jun-2016 04:18
How can I monitor the member's loopback port ,when i use ltm npath mode? ltm npath mode: https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-implementations-11-5-1/4.pri...
21-May-2020 01:08
Should be, unless someone changes that. That is why you'd want to monitor it's availability or more importantly, you want to monitor if actual service (http, smtp rtc) is running on the loopback interface.
21-Jun-2016 10:23
You would monitor the members using the non-loopback address. In the example document that would be 10.1.1.11.
09-May-2017 02:36
You can use a monitor with following parameters:
Stanislas
