Brian_Mayer_841's avatar
Brian_Mayer_841
Jan 18, 2012
Having some trouble configuring a custom health monitor..
So, I've a unique requirement to ensure our ISA servers (in a pool together, on tcp/443) are both sending traffic into our Exchange organization for external webmail. We really need the LTM to check that the traffic is being forwarded back to Exchange on each pool member ISA host.
Right now, I'm only confirming that HTTPS is responding. However, I'd like to call the OWA webmail page, which is accessible at a URI of /owa on each server. There are two distinct challenges that I'm facing:
1. The ISA proxy requires a host name in the HTTP GET request (corp.mail.company.com, for example), as it routes the traffic based on the installed SSL certificate which specifies the host name of the site. Therefore, the custom monitor also needs to include the host header.
2. The Exchange webmail site issues a basic authentication challenge to any incoming requests, so I need the ability to respond with a username and password in the custom health monitor as well.
I've gone to this URL - http://devcentral.f5.com/wiki/AdvDesignConfig.HTTPMonitor_cURL_GETWithHostSpecificHeaders.ashx - and have setup a custom monitor that maps the site host name to each specific pool member. In fact, I've actually created two custom monitors. One maps the first ISA pool member IP address to the host name corp.mail.company.com). The second maps the other ISA pool member IP address to the host as well. Is it possible for me use just one monitor to check the status of both? I noticed that the custom monitor was only assignable to a pool, not to a specific node, which is what I thought I would need to do.
I've included the text of both monitors below. My questions are:
-Can I accomplish what I'm trying to do with one health monitor or do I need two separate ones (for each pool member)?
-How do respond/reply to the browser basic authentication challenge to get into the mail system?
Thank much in advance for any input!
-B
1st custom monitor:
!/bin/sh
(c) Copyright 1996-2007 F5 Networks, Inc.
This software is confidential and may contain trade secrets that are the
property of F5 Networks, Inc. No part of the software may be disclosed
to other parties without the express written consent of F5 Networks, Inc.
It is against the law to copy the software. No part of the software may
be reproduced, transmitted, or distributed in any form or by any means,
electronic or mechanical, including photocopying, recording, or information
storage and retrieval systems, for any purpose without the express written
permission of F5 Networks, Inc. Our services are only available for legal
users of the program, for instance in the event that we extend our services
by offering the updating of files via the Internet.
@() $Id: http_monitor_cURL+GET+HostSpecificHeaders,v 1.0 2007/06/28 15:03:15 deb Exp $
(based on sample_monitor,v 1.3 2005/02/04 18:47:17 saxon)
these arguments supplied automatically for all external monitors:
$1 = IP (nnn.nnn.nnn.nnn notation)
$2 = port (decimal, host byte order)
additional command line arguments ($3 and higher) may be specified in the monitor template
This example does not expect any additional command line arguments
Name/Value pairs may also be specified in the monitor template
This example expects the following Name/Vaule pairs:
URI = the URI to request from the server
RECV = the expected response (not case sensitive)
remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
NODE=`echo ${1} | sed 's/::ffff://'`
PORT=${2}
PIDFILE="/var/run/`basename ${0}`.${NODE}_${PORT}.pid"
kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
echo "EAV exceeded runtime needed to kill ${IP}:${PORT}" | logger -p local0.error
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
set the value for the Host header based on IP
(defaults to IP address if IP doesn't match)
case "$IP" in
"192.168.1.100")
HOST="corp.mail.company.com"
HOST="$IP"
esac
send request & check for expected response
curl -fNs http://${NODE}:${PORT}${URI} -H "Host: ${HOST}" | grep -i "${RECV}" 2>&1 > /dev/null
mark node UP if expected response was received
if [ $? -eq 0 ]
then
echo "UP"
fi
rm -f $PIDFILE
exit
2nd custom monitor:
!/bin/sh
PORT=${2}
if [ -f $PIDFILE ]
then
fi
case "$IP" in
"192.168.1.101")
HOST="$IP"
esac
if [ $? -eq 0 ]
then
echo "UP"
fi
rm -f $PIDFILE
exit
  • Hi Brian,
    I think you can use a single inbuilt HTTPS monitor for this. The send string would be something like this:
    GET /owa HTTP/1.1\r\nHost: corp.mail.company.com\r\nConnection: Close\r\n\r\n
    You'd set the username and password in the monitor fields.
    If this doesn't work you can check this article for troubleshooting suggestions:
    sol12531: Troubleshooting health monitors
    http://support.f5.com/kb/en-us/solutions/public/12000/500/sol12531.html
    or this one:
    Troubleshooting LTM monitors
    http://devcentral.f5.com/wiki/AdvDesignConfig.TroubleshootingLtmMonitors.ashx
    Aaron
