John_Van_Zant's avatar
John_Van_Zant
Sep 09, 2022
Solved
GUI restarts when checking Certs on appliance
I have a pair that is in my development environment and I am experiencing something that I hope some can point me in the right direction.
Every time I try to access the Cert area under system, the gui reboots.  It take maybe 2 mins and then I can click ok and then try to access the cert area again and it works.
This happens each time and I am not even sure of what logs or where to check to see errors.  Any ideas?
  • Hello John,
    It seems you don't have enough resources in the management plane to show those certs in the first instance. Have you tried to increase the provisioning value from small to medium or large (depending on the volume of available certs in your device)?
    https://support.f5.com/csp/article/K26427018
  • Hello John,
