Abdessalem's avatar
Abdessalem
Dec 09, 2021
GTM_difference bash vs tmos
Hi F5 community
by mistake I typed the shutdown command in CLI in tmos mode and I lost the hand on the equipment.
For this I have questions please:
  • what is the difference between the two mode tmos and bash
  • why as on other technology and supplier,it did not confirm the action and took it directly into consideration.
  • When the box is in standby, can it be accessed via console to reboot it without moving to the site and pressing the box button?
  • is that there is a mode with less privilege (for example does not allow config execution)
Abdessalem
