Nasim_67664's avatar
Nasim_67664
7 years ago
Solved
Getting module 'signal' has no attribute 'SIGALRM' error from f5-sdk on Windows
I am trying to use python sdk for F5 from here https://github.com/F5Networks/f5-common-python. I am on Windows. I am running Python 3 (tried python 3.3.5 and python 3.5.4). I am getting the following error when I run this (some information masked):
from import ManagementRoot
mgmt = ManagementRoot("...", "...", "...")
File "...\lib\site-packages\f5\bigip__init__.py", line 150, in init self.post_configuration_setup()
File "...\lib\site-packages\f5\bigip__init__.py", line 111, in post_configuration_setup self._get_tmos_version()
File "...\lib\site-packages\f5\bigip__init__.py", line 117, in _get_tmos_version signal.signal(signal.SIGALRM, timeout_handler)
AttributeError: module 'signal' has no attribute 'SIGALRM'
Pip shows it installed version 3.0.8 of f5-sdk.
How can I run this from python?
Thanks.
