s3s1277_111291's avatar
s3s1277_111291
Jan 18, 2013
ftp iRule question
I've used this, to capture ftp username from tcp payload.
https://devcentral.f5.com/wiki/iRul...gging.ashx
However, is there a way to match the captured username with a datagroup, that contains list of usernames, and decide to route to a pool xyz? The datagroup type string in v10 takes string and value, while I have list of usernames only. and can I put that in the CLIENT_DATA event within the same iRule? Doesn't seem to work for me.
  • i do not think you can use FTP Session Logging codeshare as a template because the 1st SERVER_DATA happens before the 1st CLIENT_DATA.
    e.g.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.252:21
       ip protocol 6
       rules myrule
       profiles {
          ftp {}
          tcp {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
       when CLIENT_ACCEPTED {
      log local0. "-"
      TCP::collect 0 0
    when CLIENT_DATA {
      log local0. "-"
      log local0. [TCP::payload]
      TCP::release
      TCP::collect
    when SERVER_CONNECTED {
      log local0. "-"
      TCP::collect
    when SERVER_DATA {
      log local0. "-"
      TCP::release
      TCP::collect
    [root@ve10:Active] config  tail -f /var/log/ltm
    Jan 19 16:27:48 local/tmm info tmm[4884]: Rule myrule : -
    Jan 19 16:27:48 local/tmm info tmm[4884]: Rule myrule : 220 (vsFTPd 2.0.5)
    Jan 19 16:27:48 local/tmm info tmm[4884]: Rule myrule : AUTH GSSAPI
    Jan 19 16:27:48 local/tmm info tmm[4884]: Rule myrule : 530 Please login with USER and PASS.
    Jan 19 16:27:48 local/tmm info tmm[4884]: Rule myrule : AUTH KERBEROS_V4
    Jan 19 16:27:50 local/tmm info tmm[4884]: Rule myrule : -
    Jan 19 16:27:50 local/tmm info tmm[4884]: Rule myrule : USER anonymous
    Jan 19 16:27:50 local/tmm info tmm[4884]: Rule myrule : 331 Please specify the password.
    Jan 19 16:27:50 local/tmm info tmm[4884]: Rule myrule : PASS
    Jan 19 16:27:50 local/tmm info tmm[4884]: Rule myrule : 230 Login successful.
    instead, i think you should use FTP proxy v10 to proxy client connection until receiving username.
    FTP proxy v10 by Bhattman
    https://devcentral.f5.com/wiki/irules.FTP-Proxy.ashx
    e.g.
    virtual bar {
       snat automap
       ip protocol 6
       rules myrule
       profiles {
          ftp {}
          tcp {}
    [root@ve10:Active] config  b pool foo1 list
    pool foo1 {
       members 200.200.200.101:21 {}
    [root@ve10:Active] config  b pool foo2 list
    pool foo2 {
       members 200.200.200.111:21 {}
    rule myrule {
      log local0. "-"
      log local0. "220\r\n"
      TCP::respond "220\r\n"
      TCP::collect
    when CLIENT_DATA {
      log local0. "-"
      if { [TCP::payload] starts_with "USER" } {
        scan [TCP::payload] {USER%s} cuser
        switch $cuser {
          "garfield" { pool foo1 }
          default { pool foo2 }
        TCP::payload replace 0 [string length [TCP::payload]] ""
        TCP::release
        return
      log local0. "530 Please login with USER and PASS.\r\n"
      TCP::respond "530 Please login with USER and PASS.\r\n"
      log local0. "-"
      log local0. "client [IP::client_addr]:[TCP::client_port] server [IP::remote_addr]:[TCP::release]"
      TCP::collect
    when SERVER_DATA {
      log local0. "-"
      if { [TCP::payload] starts_with "220" } {
        TCP::respond "USER $cuser\r\n"
      TCP::release
     anonymous
    [root@centos251 ~] ftp 172.28.19.252
    Connected to 172.28.19.252.
    220
    KERBEROS_V4 rejected as an authentication type
    Name (172.28.19.252:root): anonymous
    Password:
    Remote system type is UNIX.
    Using binary mode to transfer files.
    ftp> ls
    227 Entering Passive Mode (172,28,19,252,122,137)
    150 Here comes the directory listing.
    drwxr-xr-x    2 0        0            4096 May 30  2011 pub
    226 Directory send OK.
    Jan 19 17:14:52 local/tmm info tmm[4884]: Rule myrule : client 172.28.19.251:44457 server 200.200.200.111:0
     garfile
    220
    Name (172.28.19.252:root): garfield
    Password:
    ftp> ls
    227 Entering Passive Mode (172,28,19,252,193,201)
    Jan 19 17:15:35 local/tmm info tmm[4884]: Rule myrule : client 172.28.19.251:44459 server 200.200.200.101:0
