Technical Forum
Form frame color apm
EYALC
Hi - Is there a way to change the frame color of the APM username and password form? It's customization - Modern Thank you very much
1 REPLY 1
Follow the next steps:
1. Going to Access  ››  Profiles / Policies : Customization : Quick Start/Basic
2.Select the Access Profiles that you want to change and select the current Language.
3.In Form Backgroud Color select the color that you want to apply.
4. Save the changes and apply the policy.
