Najm's avatar
Najm
Icon for Cirrus rankCirrus
Nov 03, 2023
Solved
fellow traffic
hi everyone!
I need to know how to check the traffic hits on specific VS whether this traffic is local or external through the CLI or configuration utility.
  • Najm You should be able using the following iRule.
    when CLIENT_ACCEPTED priority 500 {
        log local0. "[virtual] - client ip=[IP::client_addr]:[TCP::client_port]"
    Alternatively, if you needed to see it right then in the CLI you can look at the connection table and look at the client_addr section to see the true client IP. The following page should provide additional information to assist you.
    https://my.f5.com/manage/s/article/K53851362
  • To check traffic hits on a specific Virtual Server (VS) in Citrix ADC through the CLI, use the command: `nsconmsg -K /var/nslog/newnslog -d stats -g service -c showstats | grep "<VS_NAME>"`. Analyze the output for hit count details.
