Technical Forum
fastl4 vs full-acceleration
Michaelyang
Hello,
When I checked what the difference between the two profiles, I found that both settings were the same.
However, I tested the application of the two different profiles, found that the transfer speed is obviously different.
I am using the VE version, so ePVA should not have an impact
What is the difference between these two profiles?
Any help is appreciated.
Thanks.
1 ACCEPTED SOLUTION
Samir
MVP
MVP
Hope below details may help you.
Full Acceleration
All traffic is load balanced using Layer 4 features, such as virtual servers that operate only on IP addresses and ports of incoming traffic. The Full acceleration mode is not compatible with Layer 7 features, such as cookie persistence, header insertion, and rules that operate on data payload content.
FastL4
The FastL4 profile is a protocol profile that you can use to manage Layer 4 (L4) traffic on the BIG-IP system. Using the FastL4 profile can increase virtual server performance and throughput for supported platforms by using the embedded Packet Velocity Acceleration (ePVA) chip to accelerate traffic.
Happy learning..
1 REPLY 1
Samir
MVP
MVP
Full Acceleration
FastL4
Happy learning..
