Anesh's avatar
Anesh
May 05, 2014
FastL4 and Hash Persistence Bug
Does the bug mentioned in the below solution apply also to Fastl4 profiles with HASH CARP persistence. Has anyone tested it?
http://support.f5.com/kb/en-us/solutions/public/12000/000/sol12078.html
  • Anesh's avatar
    Anesh
    I will answer my own question
    As per F5 "ID 223885 The hash persist profile was extended in 10.0 with new options, but is no longer supported in combination with FastL4 virtuals."
    hence f5 is further limited in its options to support Applications that have the following features
    • long-lived and and require persistent connection to a server through out the life time of a session
    • require SSL passthrough
