09-May-2023 06:34
is that applicable to apply the waf policy on a virtual server configured on port HTTP
Solved! Go to Solution.
09-May-2023 10:56
The WAF policy does not specifically have to be attached to a virtual server that is listening on the HTTP port (I assume you mean 80 or 443?). However, any virtual server that you would like to attach a WAF policy to, must have an HTTP profile attached to it, as WAF policies can only work with HTTP traffic (whichever port it may be coming in on).
Hope this helps, but if I misunderstood your question, let me know!
09-May-2023 10:56
09-May-2023 20:06
thanks Alex , that what i need
16-May-2023 21:38
Marking this as the Accepted Solution. 🙂
