Technical Forum
F5 VPN client - silent installation
Edouard
MVP
MVP
Hello,
Is it possible to install BIGIPEdgeClient.exe silently without being promped to enter admin credentials ?
My computers are domain joined and managed via SCCM.
Thanks,
Edouard.
1 REPLY 1
Yes it is. You need to use SCCM to deploy the BIG-IP component installer which has the required administrator permissions to deliver the VPN client without prompting. One installed you should be able to deploy the VPN package seemlessly on the endpoint with the right configuration.
Deployment options | BIG-IP Edge Client operations guide (f5.com)
