Technical Forum
Custom Alert Banner
F5 SSL Offload behind Nginx Reverse Proxy
delassiops
i have nginx open source listening on http 80 port, i went to use it behind f5 with ssl offloading, how to configure the f5 virtual host with pools or F5 Application Services Templates,
Thanks,
My nginx.conf file
server {
listen 80;
server_name test.lab.dev;
location / {
try_files $uri $uri @test;
location @test {
proxy_pass http://127.0.0.1:8080;
# Pass the client informations the the backend
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $http_host;
# By default we dont want redirect it
proxy_redirect off;
# Cache
proxy_buffering off;
proxy_cache off;
1 ACCEPTED SOLUTION
Ahmed_Galal
you will configure pool member with reverse proxy IP:Port then you will configure VS with client side SSL profile, Auotmap, X-Forward HTTP Profile and map VS to this pool .
1 REPLY 1
Ahmed_Galal
