12-May-2023 08:12
i'm trying to to the following job:
when someone try to browse to ictservice.it/some_text/etc
i want the policy to add the string ICTDesktop int the path -> ictservice.it/ICTDesktop/some_text/etc
and only after forward the traffic to the Pool.
Possibly 'ICTDesktop' to be hiden
How can i do this without irule, but using only TCL or also without TCL?
thanks
Arlind
Solved! Go to Solution.
22-May-2023 13:46
solved as tcl[HTTP::uri "/ICTDesktop[HTTP::uri]"]
ps: also tcl[HTTP::path "/ICTDesktop[HTTP::path]"] works
12-May-2023 13:41
@ArlindT This might do what you want, this is also assuming I understood the situation.
when HTTP_REQUEST priority 500 {
if {[HTTP::host] == "ictservice.it"} {
if {[[string tolower [HTTP::uri]] == "/some_text/etc"} {
HTTP::uri [string map {"/some_text/etc" "/ICTDesktop/some_text/etc"}[HTTP::uri]]
pool POOL_your_pool
13-May-2023 01:37
thanks for the support,
the challenging thing is this: some_text/etc is a random part, i don't know it before.
I want something like this:
tcl:[string map {random_uri "/ICTdesktop"+random_uri} [HTTP::uri]]
so it adds /ICTdesktop before the random_uri with a tcl implementation.
13-May-2023 02:56
i was thinking something like that
tcl:[
set old_path [HTTP::path]
set new_path /ICTdesktop${old_path}
string map [list "$old_path" "$new_path"] [HTTP::uri]
13-May-2023 14:08
@ArlindT I don't believe this would work well with a string map because a string map works off of a static value being changed to another static value. What is the reason behind having to insert the "/ICTdesktop" into the path? This might be something that is better taken care of on the server side and letting the client see the path rather than attempting to hide it from the client.
14-May-2023 01:15
we had this request to balance:
node1/ICTdesktop
node2/ICTdesktop
pool1( node1 + node2) -> policy ictservice.it/variable_path
the requester want ictservice.it/variable_path
to be processed as ictservice.it/ICTdesktop/variable_path
you think this is better to be done Server side, or can be done also F5 side?
22-May-2023 13:46
