Technical Forum
Custom Alert Banner
F5 ip address exception don't work
DanieleS9
I have a problem with this IP exception.
The request from this IP are always blocked and I see the learning suggestions...
Particular tip: I set the XFF to Trust so in the requests I see the from ip address in the "source address" field correctly. I don't know if this could be the problem.
1 REPLY 1
Hassan_Ali_97
Hi ,
Try to enable the Policy Builder trusted IP and test.
Thanks,
