Moinul_Rony's avatar
Moinul_Rony
Jul 01, 2020
F5 Hardware refresh
Hi Guys,
I am planning for a refresh to our existing EOS F5 LTM Platform 3600 (running LTM, ASM, SSL) to new i2600.
Anyone went through similar refresh? I would like to have some suggestions and hints of any issues faced while doing the refresh.
My software is also EOS 11.6.3 and the target software is v15.
Cheers.
  • I have migrated 3600 LTM Platform to i5000 series but make sure software version should be same on OLD and NEW load balacner.
    # Make current 3600 LB to 11.x.x ==> 12.x ==> 13.x
    # Make i2600 Series to 13.x and install UCS.
    # Later move to 15.x stable version.
    Else Lot of issue will come and difficult to solve in limited time window. Best to connect with professional support if any questions.
    • Moinul_Rony's avatar
      Moinul_Rony
      Hi Samir,
      Thanks for your reply.
      Did you perform platform migrate option.
      Do you have the steps handy? Also is 3600 able to go > 12 > 13 ? I heard from F5 there could be limitation. But based on your comment I will get back to F5.
      Cheers,
      Rony
