Technical Forum
F5 hardwarde intel QAT
reddev12
Altocumulus
Altocumulus
Hello ,
How can we check if our F5 platform (VE on hypervisor ) has intel QAT enabled or not . Is there any tmsh command
Related to this CVE-2022-41983
1 ACCEPTED SOLUTION
Lyle_Parks
F5 Employee
F5 Employee
You need an add-on license on VE to use Intel QAT for SSL. You can check so see if  "VE SSL Compression Offload" is available in the active modules in 'tmsh show sys license detail'. If not, your VE cannot use it.
3 REPLIES 3
Lyle_Parks
F5 Employee
F5 Employee
reddev12
Altocumulus
Altocumulus
Thanks @Lyle_Parks
Do you have any snippet from your setup that shows that license is active on device  ...so that i can confirm to my customer what its like .Since i dont see in my lab setup .
Only this i see :
SSL, VE
HI suraj12:
You can confirm that the license page should be able to see this information.
https://support.f5.com/csp/article/K16538
have a good day!
