F5 error logmysqld
f5beginner
Hi All,
I have problem after reboot virtual F5 I have this error:
logmysqld[22914] Fatal error db.cpp:exec_query:150 SELECT COUNT(*) from log_data_current errno[23] strerror[Out of resources when opening file './logdb/log_data_current.MYD' (Errcode: 24)
anothere error:
Fatal error db.cpp:exec_query:150 CREATE TABLE IF NOT EXISTS log_data_0 (
Could you please help me with ?
Thank you
3 REPLIES 3
Xavier_Baugniet
Altocumulus
Altocumulus
Hello,
We just encounter the right same issue for 1 month now and can't solve it.
Did you manage to overcome it?
Thx,
Can you check and repair sql database?
https://support.f5.com/csp/article/K05755225
I found this article quite a time ago, but didn't give it a try because the error was different. But finally, I tested the procedure and it looks to be stable now 🙂
