25-May-2022 22:07
Hi all
i have clients connecting through F5 edge client - the physical address part comes in empty - is it possible to assign a value to that ?
thanks
PPP adapter _Commonxxxxxxxx:
Connection-specific DNS Suffix . : xxxxxx.com
Description . . . . . . . . . . . : _Common_xxxxxxxx
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 10.10.10.10(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
26-May-2022 15:52
thanks for the reply - i read the article - but it does not state anything about - assigning a MAC address to the edge client .
there is no problem with connectivity - its just that i want to assign a MAC address to that PPP connection
