28-Nov-2022 21:14
Hi
Refer to https://support.f5.com/csp/article/K3727. We should use different name and different match message from the one in alert.conf
If I want to set email alert on CPU temp high (this stanza is in alert.conf)
alert BIGIP_SYSTEM_CHECK_E_CPU_TEMP_HIGH {
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.4";
lcdwarn description="CPU Temp too high." priority="3"
How can i do it in user_alert.conf? Should I just copy above stanza into user_alert.conf?
eg.
alert BIGIP_SYSTEM_CHECK_E_CPU_TEMP_HIGH { >>>> same name
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.4"; >>> same oid
lcdwarn description="CPU Temp too high." priority="3";
email toaddress="test@test.com
fromaddress="f5@test.com
Solved! Go to Solution.
28-Nov-2022 23:44
Hi @kridsana ,
According this KB : " https://support.f5.com/csp/article/K3667 " it should work.
Reards
28-Nov-2022 23:44
Hi @kridsana ,
Reards
