  • It depends on what you mean by automating a backup. Do you want to take UCS Backups? TXT File Backups?
    CRON Jobs from a Linux Box Box can automate everything. Any major monitoring solutions can automate UCS and TXT File backups. BigIQ automates this process. Old EM still works and takes UCS backup Jobs.
    • Nilesh_Dubey_36's avatar
      Nilesh_Dubey_36
      Hi Dali,
      Thanks for sharing the useful article. In my case ssh is already configured so do I still require to generate crypto key and why do we require to generate it?
      Thanks,
  • Hi Den,
    I looking for UCS backup. Can you please share the method to configure the same.
    Thanks,
  • Check out GitHub for the latest version of the F5 Automated Backup iApp, and submit any bugs or questions as an "Issue" on GitHub:
    https://github.com/tabernarious/f5-automated-backup-iapp
