28-Feb-2023 08:59
Good morning Gents,
I have a F5 Infrastructure running with LTM/APM/AFM and we would like to add there ASM.
Could you please advise the system requirements to have those 4 modules in an instance.
Thanks,
Edouard.
28-Feb-2023 09:41
Hi @Edouard,
do you have an F5 device? or VE machine?
In the case of a VE please refer to this link:
03-Mar-2023 02:00
Hi @Edouard,
It gonna depend on the device you have VCMP, the minimum requirement will be 2 CPU for the guest of LTM+ASM, but if you process a lot of traffic the most recommended will be 4 CPUs, in some cases, you have to dedicate all resources of the device to ASM+LTM depending of the number of webs you want to protect, type of traffic for the webs, type of protection you enabled, etc, etc.
