Cory_Blankenshi's avatar
Cory_Blankenshi
Mar 15, 2018
F5 / APM / IdP / CorpU / Missing SAML Attributes
Hi all,
I am having some difficulty setting up our F5 as an IdP for SAML federation with the CorpU application. I have the IdP configuration set up, the SP connector created based on the metadata export from CorpU, and an APM policy set up to to the LDAP auth check and assign the SAML resource if the auth check is successful.
The issue I'm running into is that, based on what I'm hearing from CorpU support, the user ID attribute isn't being sent in the SAML request (that's the only attribute I'm trying to send). I've configured the SAML attributes in the APM SAML IdP configuration to the vendor's spec (at least they've told me everything looks fine), but I'm running out of tweaks I can make on the F5 side.
If anyone has seen an issue like this before and has can offer any thoughts on a possible solution, I would greatly appreciate it. If you need me to add any configuration info to the thread, let me know.
Thanks Everyone!
