28-Nov-2022 23:16
Dear Experts,
I am looking for setup F5 APM home lab, can you please guide me how to prepare it what are the backend server required if any one of you done kindly share the list of the coustomize backend server anything please
Solved! Go to Solution.
29-Nov-2022 00:10
Hi aali86,
The list of backend servers really depend on what you want to test or how your solution should look like.
A getting started lab should at least include a User-Repository of your choice (e.g. AD, LDAP, Radius, SAML, RSA) and a webserver who could serve a couple independent sample websites.
To test every aspect of APM in your lab (that will be a huge life lession), you may end with one or more backend servers hosting lots of different services to cover the sheer endless APM usecases...
If you have never worked with APM before then take a look to some APM class instructions, they may give you some hints what could be done with APM written for starters:
https://clouddocs.f5.com/training/community/iam/html/archived/class9/module2/module2.html
Cheere, Kai
29-Nov-2022 00:18
Depending on what do you need to experiment:
Basic beginner setup
Any setup with any web application hosted behind APM can help you learn lot of things like:
Advanced setup
A more advanced setup I would recommend will include:
With this you can test:
29-Nov-2022 00:10
Hi aali86,
Cheere, Kai
29-Nov-2022 00:18
Advanced setup
