an "External Monitor" based on external BASH-Scripts is most likely used for rather complex monitoring tasks and should not used for simple monitoring tasks. It would just add unnessecary complexity....
The curl commands your DEVs handed out are looking very simplistic and right now I dont see a good reason to put those CURL commands natively into an external monitoring script. A regular HTTP/HTTPS Monitor with tailordered SEND/RECEIVE strings should be able monitor the availability of your application.
Before helping you to create SEND/RECEIVE strings, you should clarify with your development why they included the -cookie directive and why they enabling the -G option (use GET instead of POST requests) if the -d option uses JSON formated params meant for POST payload. The combination of -G and JSON formated payload results in a slighly broken request URI:
"}},"componentScriptGroups({\"componentId\":\"custom.widget.Beta_Footer\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"component({\"componentId\":\"custom.widget.Tag_Manager_Helper\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:305246\"],\"name\":\"ForumMessagePage\",\"props\":{},\"url\":\"https://community.f5.com/discussions/technicalforum/external-monitor-with-curl-command/305246\"}}})":{"__typename":"ComponentRenderResult","html":" "}},"componentScriptGroups({\"componentId\":\"custom.widget.Tag_Manager_Helper\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"component({\"componentId\":\"custom.widget.Consent_Blackbar\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:305246\"],\"name\":\"ForumMessagePage\",\"props\":{},\"url\":\"https://community.f5.com/discussions/technicalforum/external-monitor-with-curl-command/305246\"}}})":{"__typename":"ComponentRenderResult","html":""}},"componentScriptGroups({\"componentId\":\"custom.widget.Consent_Blackbar\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"featuredContentWidget({\"coreNodeId\":\"board:TechnicalForum\",\"instanceId\":\"featuredWidgets.widget.featuredContentWidget-1705956211049\",\"quiltId\":\"ForumMessagePage\"})":{"__typename":"FeaturedContentWidget","messages({\"first\":3})":{"__typename":"MessageConnection","totalCount":2,"edges":[{"__typename":"MessageEdge","node":{"__ref":"TkbTopicMessage:message:340911"}},{"__typename":"MessageEdge","node":{"__ref":"TkbTopicMessage:message:340701"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null}},"lastModified":1745603408966,"lastModifiedUser":{"__ref":"User:user:7"}},"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/EscalatedMessageBanner\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/users/UserLink\"]})":[{"__ref":"CachedAsset:text:en_US-components/users/UserLink-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserRank\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserRank-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageTime-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSolvedBadge\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSubject\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSubject-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageBody\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageBody-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageCustomFields\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageCustomFields-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageReplyButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageReplyButton-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageListMenu\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageListMenu-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/common/Pager/PagerLoadMore\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewCard\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewCard-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/customComponent/CustomComponent\"]})":[{"__ref":"CachedAsset:text:en_US-components/customComponent/CustomComponent-1748534153693"}],"message({\"id\":\"message:305328\"})":{"__ref":"ForumReplyMessage:message:305328"},"message({\"id\":\"message:305351\"})":{"__ref":"ForumReplyMessage:message:305351"},"coreNode({\"id\":\"community:zihoc95639\"})":{"__ref":"Community:community:zihoc95639"},"message({\"id\":\"message:340911\"})":{"__ref":"TkbTopicMessage:message:340911"},"message({\"id\":\"message:340701\"})":{"__ref":"TkbTopicMessage:message:340701"},"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/common/ExternalLinkWarningModal\"]})":[{"__ref":"CachedAsset:text:en_US-components/common/ExternalLinkWarningModal-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/attachments/AttachmentView/AttachmentViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/attachments/AttachmentView/AttachmentViewChip-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1748534153693"}],"cachedText({\"lastModified\":\"1748534153693\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/nodes/NodeIcon\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1748534153693"}]},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"User:user:-1":{"__typename":"User","id":"user:-1","entityType":"USER","eventPath":"community:zihoc95639/user:-1","uid":-1,"login":"Former Member","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"dd-MMM-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":null,"possibleValues":["en-US","en-GB","de-DE"]},"repliesSortOrder":{"__typename":"InheritableStringSettingWithPossibleValues","key":"config.user_replies_sort_order","value":"DEFAULT","localValue":"DEFAULT","possibleValues":["DEFAULT","LIKES","PUBLISH_TIME","REVERSE_PUBLISH_TIME"]}},"deleted":false},"CachedAsset:pages-1748335104638":{"__typename":"CachedAsset","id":"pages-1748335104638","value":[{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetInvolved.MvpProgram","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved/mvp-program","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetInvolved.AdvocacyProgram","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved/advocacy-program","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetHelp.NonCustomer","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/non-customer","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetHelp.F5Customer","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/f5-customer","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"WorkstreamsPage","type":"COMMUNITY","urlPath":"/workstreams","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetInvolved","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.Learn","type":"COMMUNITY","urlPath":"/c/how-do-i/learn","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739501996000,"localOverride":null,"page":{"id":"Test","type":"CUSTOM","urlPath":"/custom-test-2","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetHelp.Community","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/community","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetInvolved.ContributeCode","type":"COMMUNITY","urlPath":"/c/how-do-i/get-involved/contribute-code","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.Learn.AboutIrules","type":"COMMUNITY","urlPath":"/c/how-do-i/learn/about-irules","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetHelp.F5Support","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/f5-support","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetHelp","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI.GetHelp.SecurityIncident","type":"COMMUNITY","urlPath":"/c/how-do-i/get-help/security-incident","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1748335104638,"localOverride":null,"page":{"id":"HowDoI","type":"COMMUNITY","urlPath":"/c/how-do-i","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}","userBanned":"We're sorry, but you have been banned from using this site.","userBannedReason":"You have been banned for the following reason: {reason}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstNDEtSzFzVEth\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstNDEtSzFzVEth","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:41":{"__typename":"Rank","id":"rank:41","position":18,"name":"Nimbostratus","color":"CCCCCC","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstNDEtSzFzVEth\"}"},"rankStyle":"FILLED"},"User:user:420123":{"__typename":"User","id":"user:420123","uid":420123,"login":"Anzine","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-2.svg?time=0"},"rank":{"__ref":"Rank:rank:41"},"email":"","messagesCount":6,"biography":null,"topicsCount":4,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-09-12T19:48:15.422-07:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:420123"},"Category:category:Forums":{"__typename":"Category","id":"category:Forums","entityType":"CATEGORY","displayId":"Forums","nodeType":"category","depth":1,"title":"Forums","shortTitle":"Forums","parent":{"__ref":"Category:category:top"},"categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:top":{"__typename":"Category","id":"category:top","entityType":"CATEGORY","displayId":"top","nodeType":"category","depth":0,"title":"Top","shortTitle":"Top"},"Forum:board:TechnicalForum":{"__typename":"Forum","id":"board:TechnicalForum","entityType":"FORUM","displayId":"TechnicalForum","nodeType":"board","depth":2,"conversationStyle":"FORUM","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"PUBLISH_TIME","repliesFormat":"threaded"},"tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":true,"tagType":"FREEFORM_AND_PRESET","description":"Ask questions.\r\nDiscover Answers.","title":"Technical Forum","shortTitle":"Technical Forum","parent":{"__ref":"Category:category:Forums"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:zihoc95639"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:Forums"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"theme":{"__ref":"Theme:customTheme1"},"boardPolicies":{"__typename":"BoardPolicies","canViewSpamDashBoard":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","args":[]}},"canArchiveMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","key":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","args":[]}},"canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}},"canManageFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","args":[]}},"canUpdateFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","args":[]}},"canReadNode":{"__typename":"PolicyResult","failureReason":null}},"linkProperties":{"__typename":"LinkProperties","isExternalLinkWarningEnabled":true},"forumPolicies":{"__typename":"ForumPolicies","canManageFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.admin_featured_widget.allowed.accessDenied","args":[]}},"canUpdateFeaturedWidget":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","key":"error.lithium.policies.feature.featured_widgets.action.update_featured_widget.allowed.accessDenied","args":[]}},"canReadNode":{"__typename":"PolicyResult","failureReason":null}},"eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/"},"ForumTopicMessage:message:305246":{"__typename":"ForumTopicMessage","uid":305246,"subject":"External Monitor with curl command","id":"message:305246","entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:305246","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:420123"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalForum"},"conversation":{"__ref":"Conversation:conversation:305246"},"readOnly":false,"editFrozen":false,"showMoveIndicator":false,"moderationData":{"__ref":"ModerationData:moderation_data:305246"},"body":"
Hi expert
i want to write script for external monitor as scenario
i have 3 pools with priority group less than 1 that mean only 1 server should accept traffic and the others are standby
the priority group as expected but the development want only 1 pool should up and others mark down by using
if send cookie with expexted respond should be OK and API ACTIVE
how to write this script, send request and respond on the file
","body@stringLength":"495","rawBody":"
Hi expert
","kudosSumWeight":0,"postTime":"2022-11-28T06:08:42.353-08:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"AttachmentEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98MQ","node":{"__ref":"Attachment:{\"id\":\"attachment:message305246AttachmentNumber1\",\"url\":\"https://community.f5.com/t5/s/zihoc95639/attachments/zihoc95639/TechnicalForum/263826/1/external%20monitor%20request%20respond%20curl.pdf\"}"}}]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:application delivery","text":"application delivery","time":"2021-06-30T01:48:44.000-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:305246_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":879},"read":false,"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"Hi expert i want to write script for external monitor as scenario i have 3 pools with priority group less than 1 that mean only 1 server should accept traffic and the others are standby the priori...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXwxMHwzOToxfGludCwzMDUzMjgsMzA1MzI4","node":{"__ref":"ForumReplyMessage:message:305328"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Conversation:conversation:305246":{"__typename":"Conversation","id":"conversation:305246","solved":false,"topic":{"__ref":"ForumTopicMessage:message:305246"},"lastPostingActivityTime":"2022-11-29T06:58:31.027-08:00","lastPostTime":"2022-11-29T06:58:31.027-08:00","unreadReplyCount":2,"isSubscribed":false},"ModerationData:moderation_data:305246":{"__typename":"ModerationData","id":"moderation_data:305246","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Attachment:{\"id\":\"attachment:message305246AttachmentNumber1\",\"url\":\"https://community.f5.com/t5/s/zihoc95639/attachments/zihoc95639/TechnicalForum/263826/1/external%20monitor%20request%20respond%20curl.pdf\"}":{"__typename":"Attachment","id":"attachment:message305246AttachmentNumber1","filename":"external monitor request respond curl.pdf","filesize":61106,"contentType":"application/pdf","url":"https://community.f5.com/t5/s/zihoc95639/attachments/zihoc95639/TechnicalForum/263826/1/external%20monitor%20request%20respond%20curl.pdf"},"Revision:revision:305246_1":{"__typename":"Revision","id":"revision:305246_1","lastEditTime":"2022-11-28T06:08:42.353-08:00"},"CachedAsset:theme:customTheme1-1748534267348":{"__typename":"CachedAsset","id":"theme:customTheme1-1748534267348","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"android-chrome-512x512-1748534255255.png","imageLastModified":"1748534256856","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"devcentral-type-lockup-1748534239063.svg","imageLastModified":"1748534240836","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1600px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_PAGE_CONTENT","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"5px","borderRadius":"5px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"14px","paddingXHero":"42px","fontStyle":"NORMAL","fontWeight":"500","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-400)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-400-h), var(--lia-bs-gray-400-s), calc(var(--lia-bs-gray-400-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-400-h), var(--lia-bs-gray-400-s), calc(var(--lia-bs-gray-400-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-300)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"NONE","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-primary)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"500","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#0C5C8D","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#62C026","blogColor":"#730015","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#C20025","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#F3704B","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#EE4B5B","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#491B62","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#0C5C8D","secondary":"#333333","bodyText":"#222222","bodyBg":"#F5F5F5","info":"#1D9CD3","success":"#62C026","warning":"#FFD651","danger":"#C20025","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#C20025","#081B85","#009639","#B3C6D7","#7CC0EB","#F29A36","#B2D7EB","#66AFD7","#007ABC","#343434"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Neusa Next Pro Wide Bold","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"30px","h2FontSize":"25px","h3FontSize":"20px","h4FontSize":"18px","h5FontSize":"16px","h6FontSize":"16px","lineHeight":"1.1","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":null,"imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"14px","defaultMessageHeaderMarginBottom":"10px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"10px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"14px","specialMessageHeaderMarginBottom":"10px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"10px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Proxima Nova A Medium","fontStyleBase":"NORMAL","fontWeightBase":"500","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.2","fontSizeBase":"15px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"13px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Proxima Nova A Medium","styles":[{"style":"NORMAL","weight":"500","__typename":"FontStyleData"}],"assetNames":["ProximaNovaAMedium-normal-500.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Neusa Next Pro Wide Bold","styles":[{"style":"NORMAL","weight":"700","__typename":"FontStyleData"}],"assetNames":["NeusaNextProWideBold-normal-700.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1748534153693","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:f5.prod:pages/forums/ForumMessagePage:board:TechnicalForum-1748534151124":{"__typename":"CachedAsset","id":"quilt:f5.prod:pages/forums/ForumMessagePage:board:TechnicalForum-1748534151124","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"featuredWidgets.widget.featuredContentWidget","className":null,"props":{"instanceId":"featuredWidgets.widget.featuredContentWidget-1705956211049","layoutProps":{"layout":"card","layoutOptions":{"useRepliesCount":false,"useAuthorRank":false,"useTimeToRead":true,"useKudosCount":false,"useViewCount":false,"usePreviewMedia":true,"useBody":false,"useCenteredCardContent":false,"useTags":true,"useTimestamp":false,"useBoardLink":true,"useAuthorLink":false,"useSolvedBadge":true}},"titleSrOnly":false,"showPager":true,"pageSize":3,"lazyLoad":false},"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"pageSize":5,"pagerVariant":{"type":"loadMore"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":false,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":true,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"lazyLoad":false,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"useTitle":true,"addTags":false,"titleContextVariant":"other","showTabs":false,"style":"compact","panelType":"standard","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"},{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","useAuthorLoginLink":true,"useNodeLink":true,"usePreviewMedia":true,"timeStampType":"postTime","useTextBody":true,"useSolvedBadge":false,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":false,"useVideoPreview":false,"portraitClampBodyLines":3,"useCompactSpacing":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":true,"useMessageTimeLink":true,"useAuthorLogin":true}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"},{"id":"custom.widget.Community_Quicklinks","className":null,"props":{"customComponentId":"custom.widget.Community_Quicklinks"},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1748534153693","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1748534153693","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:f5.prod:Common:1748534149394":{"__typename":"CachedAsset","id":"quiltWrapper:f5.prod:Common:1748534149394","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#66AFD7","items":[{"id":"custom.widget.GainsightShared","props":{"widgetVisibility":"signedInOnly","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Beta_MetaNav","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"700","controllerHighlightColor":"#F29A36","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":1,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"48px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"unset","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"#343434","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-dark)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"#B2D7EB","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"#343434","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid #343434","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"#343434","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"#343434"},"links":{"sideLinks":[],"logoLinks":[],"mainLinks":[{"children":[{"linkType":"INTERNAL","id":"migrated-link-1","params":{"boardId":"TechnicalForum","categoryId":"Forums"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-2","params":{"boardId":"WaterCooler","categoryId":"Forums"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-0","params":{"categoryId":"Forums"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-4","params":{"boardId":"codeshare","categoryId":"CrowdSRC"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-5","params":{"boardId":"communityarticles","categoryId":"CrowdSRC"},"routeName":"TkbBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-3","params":{"categoryId":"CrowdSRC"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-7","params":{"boardId":"TechnicalArticles","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"article-series","params":{"boardId":"article-series","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"security-insights","params":{"boardId":"security-insights","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-8","params":{"boardId":"DevCentralNews","categoryId":"Articles"},"routeName":"TkbBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-6","params":{"categoryId":"Articles"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-10","params":{"categoryId":"CommunityGroups"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"migrated-link-11","params":{"categoryId":"F5-Groups"},"routeName":"CategoryPage"}],"linkType":"INTERNAL","id":"migrated-link-9","params":{"categoryId":"GroupsCategory"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-12","params":{"boardId":"Events","categoryId":"top"},"routeName":"EventBoardPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-13","params":{"boardId":"Suggestions","categoryId":"top"},"routeName":"IdeaBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"Common-external-link","url":"https://community.f5.com/c/how-do-i","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__lQ9Z6","showSearchIcon":false,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"transparent","visualEffects":{"showBottomBorder":false},"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"#222222"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"#007ABC","linkHighlightColor":"#FFFFFF","visualEffects":{"showBottomBorder":false},"backgroundOpacity":100,"linkTextColor":"#FFFFFF"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-body-color)","items":[{"id":"custom.widget.Beta_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Tag_Manager_Helper","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Consent_Blackbar","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1748534153693","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.GainsightShared-en-us-1748334818906":{"__typename":"CachedAsset","id":"component:custom.widget.GainsightShared-en-us-1748334818906","value":{"component":{"id":"custom.widget.GainsightShared","template":{"id":"GainsightShared","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Shared functions for Gainsight integration","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GainsightShared","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Shared functions for Gainsight integration","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Beta_MetaNav-en-us-1748334818906":{"__typename":"CachedAsset","id":"component:custom.widget.Beta_MetaNav-en-us-1748334818906","value":{"component":{"id":"custom.widget.Beta_MetaNav","template":{"id":"Beta_MetaNav","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"MetaNav menu at the top of every page.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Beta_MetaNav","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"MetaNav menu at the top of every page.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Community_Quicklinks-en-us-1748334818906":{"__typename":"CachedAsset","id":"component:custom.widget.Community_Quicklinks-en-us-1748334818906","value":{"component":{"id":"custom.widget.Community_Quicklinks","template":{"id":"Community_Quicklinks","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Community_Quicklinks","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Beta_Footer-en-us-1748334818906":{"__typename":"CachedAsset","id":"component:custom.widget.Beta_Footer-en-us-1748334818906","value":{"component":{"id":"custom.widget.Beta_Footer","template":{"id":"Beta_Footer","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"DevCentral´s custom footer.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Beta_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"DevCentral´s custom footer.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Tag_Manager_Helper-en-us-1748334818906":{"__typename":"CachedAsset","id":"component:custom.widget.Tag_Manager_Helper-en-us-1748334818906","value":{"component":{"id":"custom.widget.Tag_Manager_Helper","template":{"id":"Tag_Manager_Helper","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Helper widget to inject Tag Manager scripts into head element","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Tag_Manager_Helper","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Helper widget to inject Tag Manager scripts into head element","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Consent_Blackbar-en-us-1748334818906":{"__typename":"CachedAsset","id":"component:custom.widget.Consent_Blackbar-en-us-1748334818906","value":{"component":{"id":"custom.widget.Consent_Blackbar","template":{"id":"Consent_Blackbar","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Consent_Blackbar","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1748534153693","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1748534153693","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/featured/content/FeaturedContentWidget-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/featured/content/FeaturedContentWidget-1748534153693","value":{"edit":"Edit Featured Content","title":"Featured Content","title@instance:iLVTsW":"Pinned Items","title@instance:featuredWidgets.widget.featuredContentWidget-1702666903735":"","title@instance:TZsNhL":"","title@instance:featuredWidgets.widget.featuredContentWidget-1702666556326":"","title@instance:featuredWidgets.widget.featuredContentWidget-1717525242793":"","title@instance:featuredWidgets.widget.featuredContentWidget-1705956211049":"","title@instance:featuredWidgets.widget.featuredContentWidget-1717525727595":"Pinned Items","title@instance:featuredWidgets.widget.featuredContentWidget-1728320145294":"Pinned Items","title@instance:featuredWidgets.widget.featuredContentWidget-1703882552800":""},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1748534153693","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1706288370055":"Content Feed","title@instance:1743095186784":"Most Recent Updates","title@instance:1704317906837":"Content Feed","title@instance:1743095018194":"Most Recent Updates","title@instance:1702668293472":"Community Feed","title@instance:1743095117047":"Most Recent Updates","title@instance:1704319314827":"Blog Feed","title@instance:1743095235555":"Most Recent Updates","title@instance:1704320290851":"My Contributions","title@instance:1703720491809":"Forum Feed","title@instance:1743095311723":"Most Recent Updates","title@instance:1703028709746":"Group Content Feed","title@instance:VTsglH":"Content Feed"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1748534153693","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"Forum:board:WaterCooler":{"__typename":"Forum","id":"board:WaterCooler","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:Articles":{"__typename":"Category","id":"category:Articles","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"Articles","nodeType":"category","depth":1,"title":"Articles","shortTitle":"Articles"},"Tkb:board:TechnicalArticles":{"__typename":"Tkb","id":"board:TechnicalArticles","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"TKB","displayId":"TechnicalArticles","nodeType":"board","depth":2,"conversationStyle":"TKB","title":"Technical Articles","shortTitle":"Technical Articles","parent":{"__ref":"Category:category:Articles"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi0zNC0xM2k0MzE3N0Q2NjFBRDg5NDAy\"}"},"description":"F5 SMEs share good practice.","eventPath":"category:Articles/community:zihoc95639board:TechnicalArticles/"},"Tkb:board:DevCentralNews":{"__typename":"Tkb","id":"board:DevCentralNews","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"TKB","displayId":"DevCentralNews","nodeType":"board","depth":2,"conversationStyle":"TKB","title":"DevCentral News","shortTitle":"DevCentral News","parent":{"__ref":"Category:category:Articles"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"eventPath":"category:Articles/community:zihoc95639board:DevCentralNews/"},"Category:category:GroupsCategory":{"__typename":"Category","id":"category:GroupsCategory","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:F5-Groups":{"__typename":"Category","id":"category:F5-Groups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:CommunityGroups":{"__typename":"Category","id":"category:CommunityGroups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Occasion:board:Events":{"__typename":"Occasion","id":"board:Events","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"occasionPolicies":{"__typename":"OccasionPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Idea:board:Suggestions":{"__typename":"Idea","id":"board:Suggestions","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"ideaPolicies":{"__typename":"IdeaPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:CrowdSRC":{"__typename":"Category","id":"category:CrowdSRC","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"CrowdSRC","nodeType":"category","depth":1,"title":"CrowdSRC","shortTitle":"CrowdSRC"},"Tkb:board:codeshare":{"__typename":"Tkb","id":"board:codeshare","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"TKB","displayId":"codeshare","nodeType":"board","depth":2,"conversationStyle":"TKB","title":"CodeShare","shortTitle":"CodeShare","parent":{"__ref":"Category:category:CrowdSRC"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi04Ny0xOTQ1NWk4ODNCOUNEMkFDNDZCQjI0\"}"},"description":"Have some code. Share some code.","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/"},"Tkb:board:communityarticles":{"__typename":"Tkb","id":"board:communityarticles","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:security-insights":{"__typename":"Tkb","id":"board:security-insights","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:article-series":{"__typename":"Tkb","id":"board:article-series","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:341643":{"__typename":"Conversation","id":"conversation:341643","topic":{"__typename":"ForumTopicMessage","uid":341643},"lastPostingActivityTime":"2025-05-31T20:14:43.346-07:00","solved":false},"ForumTopicMessage:message:341643":{"__typename":"ForumTopicMessage","subject":"How to get group name CN from session.ad.last.attr.memberOf when there are multiple attribute value","conversation":{"__ref":"Conversation:conversation:341643"},"id":"message:341643","entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:341643","revisionNum":1,"uid":341643,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":434885,"login":"heenakhanam0708","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":29},"postTime":"2025-05-30T00:13:26.773-07:00","lastPublishTime":"2025-05-30T00:13:26.773-07:00","readOnly":false},"Conversation:conversation:341605":{"__typename":"Conversation","id":"conversation:341605","topic":{"__typename":"ForumTopicMessage","uid":341605},"lastPostingActivityTime":"2025-05-31T20:00:12.463-07:00","solved":false},"ForumTopicMessage:message:341605":{"__typename":"ForumTopicMessage","subject":"Adding member 3 to an existing cluster","conversation":{"__ref":"Conversation:conversation:341605"},"id":"message:341605","entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:341605","revisionNum":1,"uid":341605,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":361813,"login":"Rafi1","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":36},"postTime":"2025-05-28T22:52:51.036-07:00","lastPublishTime":"2025-05-28T22:52:51.036-07:00","readOnly":false},"Conversation:conversation:341645":{"__typename":"Conversation","id":"conversation:341645","topic":{"__typename":"ForumTopicMessage","uid":341645},"lastPostingActivityTime":"2025-05-30T08:37:01.805-07:00","solved":false},"ForumTopicMessage:message:341645":{"__typename":"ForumTopicMessage","subject":"Lab with F5OS","conversation":{"__ref":"Conversation:conversation:341645"},"id":"message:341645","entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:341645","revisionNum":1,"uid":341645,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":436345,"login":"Antonio_Garcia","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":40},"postTime":"2025-05-30T06:04:43.792-07:00","lastPublishTime":"2025-05-30T06:04:43.792-07:00","readOnly":false},"Conversation:conversation:341593":{"__typename":"Conversation","id":"conversation:341593","topic":{"__typename":"ForumTopicMessage","uid":341593},"lastPostingActivityTime":"2025-05-30T08:14:53.578-07:00","solved":false},"ForumTopicMessage:message:341593":{"__typename":"ForumTopicMessage","subject":"R-Series after upgrading to 1.8 - RADIUS Auth stopped working","conversation":{"__ref":"Conversation:conversation:341593"},"id":"message:341593","entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:341593","revisionNum":1,"uid":341593,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":241271,"login":"Dave_Mehlberg","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":36},"postTime":"2025-05-28T09:30:02.593-07:00","lastPublishTime":"2025-05-28T09:30:02.593-07:00","readOnly":false},"Conversation:conversation:341613":{"__typename":"Conversation","id":"conversation:341613","topic":{"__typename":"ForumTopicMessage","uid":341613},"lastPostingActivityTime":"2025-05-30T08:02:15.644-07:00","solved":false},"ForumTopicMessage:message:341613":{"__typename":"ForumTopicMessage","subject":"F5 Out of date jQuery bootstrap version","conversation":{"__ref":"Conversation:conversation:341613"},"id":"message:341613","entityType":"FORUM_TOPIC","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:341613","revisionNum":1,"uid":341613,"depth":0,"board":{"__ref":"Forum:board:TechnicalForum"},"author":{"__typename":"User","uid":429598,"login":"GDC1-TRG-F5","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false},"metrics":{"__typename":"MessageMetrics","views":34},"postTime":"2025-05-29T02:37:07.739-07:00","lastPublishTime":"2025-05-29T02:37:07.739-07:00","readOnly":false},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMS01bkFrOTY\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMS01bkFrOTY","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:1":{"__typename":"Rank","id":"rank:1","position":0,"name":"Admin","color":"C20025","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMS01bkFrOTY\"}"},"rankStyle":"FILLED"},"User:user:7":{"__typename":"User","id":"user:7","uid":7,"login":"LiefZimmerman","biography":"Point of contact for the DevCentral Community platform (and structure of community.f5.com). I aim to make DevCentral work *for you*.","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-01-20T08:54:30.112-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS03LTVnQ0JFWg?image-coordinates=0%2C0%2C200%2C200"},"rank":{"__ref":"Rank:rank:1"},"messagesCount":984,"kudosGivenCount":1206,"kudosReceivedCount":561,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":18,"entityType":"USER","eventPath":"community:zihoc95639/user:7"},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi0zNC0xM2k0MzE3N0Q2NjFBRDg5NDAy\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bi0zNC0xM2k0MzE3N0Q2NjFBRDg5NDAy","mimeType":"image/png"},"TkbTopicMessage:message:289008":{"__typename":"TkbTopicMessage","uid":289008,"subject":"External Monitor Information and Templates","id":"message:289008","entityType":"TKB_ARTICLE","eventPath":"category:Articles/community:zihoc95639board:TechnicalArticles/message:289008","revisionNum":2,"repliesCount":0,"author":{"__ref":"User:user:7"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:TechnicalArticles"},"conversation":{"__ref":"Conversation:conversation:289008"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:289008"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2020-05-19T12:59:10.000-07:00","lastPublishTime":"2025-01-27T10:16:42.517-08:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":4555},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null},"Conversation:conversation:289008":{"__typename":"Conversation","id":"conversation:289008","solved":false,"topic":{"__ref":"TkbTopicMessage:message:289008"},"lastPostingActivityTime":"2025-01-27T10:16:42.517-08:00","lastPostTime":"2020-05-19T12:59:10.000-07:00","isSubscribed":false},"ModerationData:moderation_data:289008":{"__typename":"ModerationData","id":"moderation_data:289008","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:289008":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:289008","relatedMessage":{"__ref":"TkbTopicMessage:message:289008"}},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMjgtQ3U0RXo2\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMjgtQ3U0RXo2","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:28":{"__typename":"Rank","id":"rank:28","position":5,"name":"Employee","color":"C20025","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMjgtQ3U0RXo2\"}"},"rankStyle":"OUTLINE"},"User:user:172159":{"__typename":"User","id":"user:172159","uid":172159,"login":"Leon_Seng","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2021-09-15T05:55:37.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS0xNzIxNTktMjA5NDNpQTcyQThGQzE5NUQ0MzZFMg"},"rank":{"__ref":"Rank:rank:28"},"messagesCount":12,"kudosGivenCount":11,"kudosReceivedCount":27,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:zihoc95639/user:172159"},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bi04Ny0xOTQ1NWk4ODNCOUNEMkFDNDZCQjI0\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bi04Ny0xOTQ1NWk4ODNCOUNEMkFDNDZCQjI0","mimeType":"image/png"},"TkbTopicMessage:message:288887":{"__typename":"TkbTopicMessage","uid":288887,"subject":"TACACS+ External Monitor (Python)","id":"message:288887","entityType":"TKB_ARTICLE","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/message:288887","revisionNum":2,"repliesCount":0,"author":{"__ref":"User:user:172159"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:codeshare"},"conversation":{"__ref":"Conversation:conversation:288887"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:288887"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2021-09-15T16:22:58.000-07:00","lastPublishTime":"2025-01-09T05:35:13.957-08:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":1318},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null},"Conversation:conversation:288887":{"__typename":"Conversation","id":"conversation:288887","solved":false,"topic":{"__ref":"TkbTopicMessage:message:288887"},"lastPostingActivityTime":"2025-01-09T05:35:13.957-08:00","lastPostTime":"2021-09-15T16:22:58.000-07:00","isSubscribed":false},"ModerationData:moderation_data:288887":{"__typename":"ModerationData","id":"moderation_data:288887","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:288887":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:288887","relatedMessage":{"__ref":"TkbTopicMessage:message:288887"}},"User:user:51154":{"__typename":"User","id":"user:51154","uid":51154,"login":"JRahm","biography":"Christ Follower, Husband, Father, Technologist. I love community and I especially love THIS community. My background is networking, but I've dabbled in all the F5 iStuff, I'm a recovering Perl guy, and am very much a python enthusiast. Learning alongside all of you in this accelerating industry toward modern apps and architectures.","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2005-01-20T00:00:00.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS01MTE1NC1uYzdSVFk?image-coordinates=0%2C0%2C1067%2C1067"},"rank":{"__ref":"Rank:rank:1"},"messagesCount":4635,"kudosGivenCount":843,"kudosReceivedCount":1067,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":91,"entityType":"USER","eventPath":"community:zihoc95639/user:51154"},"TkbTopicMessage:message:285358":{"__typename":"TkbTopicMessage","uid":285358,"subject":"snmp-check external monitor","id":"message:285358","entityType":"TKB_ARTICLE","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/message:285358","revisionNum":2,"repliesCount":5,"author":{"__ref":"User:user:51154"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:codeshare"},"conversation":{"__ref":"Conversation:conversation:285358"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:285358"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2020-03-16T14:28:50.000-07:00","lastPublishTime":"2025-01-27T12:12:54.020-08:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":2021},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null},"Conversation:conversation:285358":{"__typename":"Conversation","id":"conversation:285358","solved":false,"topic":{"__ref":"TkbTopicMessage:message:285358"},"lastPostingActivityTime":"2025-01-27T12:12:54.020-08:00","lastPostTime":"2020-05-07T12:25:20.000-07:00","isSubscribed":false},"ModerationData:moderation_data:285358":{"__typename":"ModerationData","id":"moderation_data:285358","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:285358":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:285358","relatedMessage":{"__ref":"TkbTopicMessage:message:285358"}},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzYtWjgzVzZJ\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMzYtWjgzVzZJ","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:36":{"__typename":"Rank","id":"rank:36","position":13,"name":"Cirrocumulus","color":"CCCCCC","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzYtWjgzVzZJ\"}"},"rankStyle":"FILLED"},"User:user:181046":{"__typename":"User","id":"user:181046","uid":181046,"login":"Leonardo_Souza","biography":"I am an F5 Expert, working as a contractor.\n\nTo know more about myself or contact me:\nhttps://uk.linkedin.com/in/leonardobdes","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2012-08-01T01:00:00.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-1.svg?time=0"},"rank":{"__ref":"Rank:rank:36"},"messagesCount":671,"kudosGivenCount":0,"kudosReceivedCount":21,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":5,"entityType":"USER","eventPath":"community:zihoc95639/user:181046"},"TkbTopicMessage:message:289137":{"__typename":"TkbTopicMessage","uid":289137,"subject":"External Monitor Templates","id":"message:289137","entityType":"TKB_ARTICLE","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/message:289137","revisionNum":1,"repliesCount":0,"author":{"__ref":"User:user:181046"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:codeshare"},"conversation":{"__ref":"Conversation:conversation:289137"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:289137"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2020-04-23T10:04:14.000-07:00","lastPublishTime":"2020-04-23T10:04:14.000-07:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":1030},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null},"Conversation:conversation:289137":{"__typename":"Conversation","id":"conversation:289137","solved":false,"topic":{"__ref":"TkbTopicMessage:message:289137"},"lastPostingActivityTime":"2020-04-23T10:04:14.000-07:00","lastPostTime":"2020-04-23T10:04:14.000-07:00","isSubscribed":false},"ModerationData:moderation_data:289137":{"__typename":"ModerationData","id":"moderation_data:289137","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:289137":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:289137","relatedMessage":{"__ref":"TkbTopicMessage:message:289137"}},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzctMmdkZklv\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMzctMmdkZklv","height":0,"width":0,"mimeType":"image/svg+xml"},"Rank:rank:37":{"__typename":"Rank","id":"rank:37","position":14,"name":"Cirrostratus","color":"CCCCCC","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMzctMmdkZklv\"}"},"rankStyle":"FILLED"},"User:user:29768":{"__typename":"User","id":"user:29768","uid":29768,"login":"hoolio","biography":"VP of Solutions at WorldTech IT","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2005-09-08T01:00:00.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/m_assets/avatars/default/avatar-7.svg?time=0"},"rank":{"__ref":"Rank:rank:37"},"messagesCount":11146,"kudosGivenCount":0,"kudosReceivedCount":13,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:zihoc95639/user:29768"},"TkbTopicMessage:message:284153":{"__typename":"TkbTopicMessage","uid":284153,"subject":"Template For External Monitors","id":"message:284153","entityType":"TKB_ARTICLE","eventPath":"category:CrowdSRC/community:zihoc95639board:codeshare/message:284153","revisionNum":1,"repliesCount":0,"author":{"__ref":"User:user:29768"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:codeshare"},"conversation":{"__ref":"Conversation:conversation:284153"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:284153"},"teaser@stripHtml({\"removeProcessingText\":false,\"truncateLength\":200})":"","postTime":"2015-03-12T15:32:54.000-07:00","lastPublishTime":"2015-03-12T15:32:54.000-07:00","readOnly":false,"introduction":"","metrics":{"__typename":"MessageMetrics","views":3526},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null},"Conversation:conversation:284153":{"__typename":"Conversation","id":"conversation:284153","solved":false,"topic":{"__ref":"TkbTopicMessage:message:284153"},"lastPostingActivityTime":"2015-03-12T15:32:54.000-07:00","lastPostTime":"2015-03-12T15:32:54.000-07:00","isSubscribed":false},"ModerationData:moderation_data:284153":{"__typename":"ModerationData","id":"moderation_data:284153","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:284153":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:284153","relatedMessage":{"__ref":"TkbTopicMessage:message:284153"}},"QueryVariables:TopicReplyList:message:305246:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:305246:1","value":{"id":"message:305246","first":10,"sorts":{"postTime":{"direction":"ASC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/community/Navbar-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1748534153693","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","migrated-link-9":"Groups","migrated-link-7":"Technical Articles","migrated-link-8":"DevCentral News","migrated-link-1":"Technical Forum","migrated-link-10":"Community Groups","migrated-link-2":"Water Cooler","migrated-link-11":"F5 Groups","Common-external-link":"How Do I...?","migrated-link-0":"Forums","article-series":"Article Series","migrated-link-5":"Community Articles","migrated-link-6":"Articles","security-insights":"Security Insights","migrated-link-3":"CrowdSRC","migrated-link-4":"CodeShare","migrated-link-12":"Events","migrated-link-13":"Suggestions"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1748534153693","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1748534153693","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1748534153693","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1748534153693","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1748534153693","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1748534153693","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solution","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1748534153693","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1748534153693","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-components/featured/content/FeaturedContentMessageList-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/featured/content/FeaturedContentMessageList-1748534153693","value":{"edit":"Edit Featured Content","header":"Featured Content"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1748534153693","value":{"title":"Query Handler"},"localOverride":false},"User:user:419489":{"__typename":"User","id":"user:419489","uid":419489,"login":"HeidiSchreifels","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-07-15T10:09:37.046-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS00MTk0ODktYU5jVHhK?image-coordinates=0%2C0%2C121%2C120"},"rank":{"__ref":"Rank:rank:28"},"messagesCount":22,"kudosGivenCount":27,"kudosReceivedCount":31,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:zihoc95639/user:419489"},"TkbTopicMessage:message:340911":{"__typename":"TkbTopicMessage","uid":340911,"subject":"The New F5 Certified BIG-IP Administrator Certification Exams Now Live","id":"message:340911","entityType":"TKB_ARTICLE","eventPath":"category:Articles/community:zihoc95639board:DevCentralNews/message:340911","revisionNum":3,"repliesCount":6,"author":{"__ref":"User:user:419489"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:DevCentralNews"},"conversation":{"__ref":"Conversation:conversation:340911"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:340911"},"teaser":"\n
","postTime":"2025-04-23T11:16:38.997-07:00","lastPublishTime":"2025-04-25T10:49:39.663-07:00","images":{"__typename":"AssociatedImageConnection","edges":[{"__typename":"AssociatedImageEdge","cursor":"MjUuNHwyLjF8b3wyNXxfTlZffDE","node":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA5MTEtOEo4VzQw?revision=3\"}"}}],"totalCount":1,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":true,"endCursor":"MjUuNHwyLjF8b3w1fF9OVl98NQ","hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98MQ","node":{"__typename":"Tag","id":"tag:101","text":"101","time":"2022-01-24T02:30:16.258-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98Mg","node":{"__typename":"Tag","id":"tag:201","text":"201","time":"2022-01-24T02:33:36.625-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98Mw","node":{"__typename":"Tag","id":"tag:administrator","text":"administrator","time":"2024-04-19T00:36:27.334-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98NA","node":{"__typename":"Tag","id":"tag:announcement","text":"announcement","time":"2021-12-19T07:45:21.000-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98NQ","node":{"__typename":"Tag","id":"tag:BIG-IP","text":"BIG-IP","time":"2022-01-24T02:29:45.031-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":3,"introduction":"","metrics":{"__typename":"MessageMetrics","views":695},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"Conversation:conversation:340911":{"__typename":"Conversation","id":"conversation:340911","solved":false,"topic":{"__ref":"TkbTopicMessage:message:340911"},"lastPostingActivityTime":"2025-04-28T08:13:10.869-07:00","lastPostTime":"2025-04-28T08:13:10.869-07:00","isSubscribed":false},"ModerationData:moderation_data:340911":{"__typename":"ModerationData","id":"moderation_data:340911","status":"APPROVED","rejectReason":null},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA5MTEtOEo4VzQw?revision=3\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA5MTEtOEo4VzQw?revision=3","title":"clipboard_image-1-1745603317979.png","associationType":"TEASER","width":610,"height":343,"altText":""},"User:user:354995":{"__typename":"User","id":"user:354995","uid":354995,"login":"Rebecca_Moloney","biography":"Content Manager at DevCentral. I'm complex like a carbohydrate.","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2019-05-30T13:15:33.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS0zNTQ5OTUtTW1jMnNa?image-coordinates=38%2C357%2C711%2C1029"},"rank":{"__ref":"Rank:rank:1"},"messagesCount":115,"kudosGivenCount":202,"kudosReceivedCount":165,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":2,"entityType":"USER","eventPath":"community:zihoc95639/user:354995"},"TkbTopicMessage:message:340701":{"__typename":"TkbTopicMessage","uid":340701,"subject":"F5 Academies Are Back – And We’re Coming to a City Near You","id":"message:340701","entityType":"TKB_ARTICLE","eventPath":"category:Articles/community:zihoc95639board:DevCentralNews/message:340701","revisionNum":12,"repliesCount":4,"author":{"__ref":"User:user:354995"},"depth":0,"hasGivenKudo":false,"helpful":null,"board":{"__ref":"Tkb:board:DevCentralNews"},"conversation":{"__ref":"Conversation:conversation:340701"},"contentWorkflow":{"__typename":"ContentWorkflow","state":"PUBLISH","scheduledPublishTime":null,"scheduledTimezone":null,"shortScheduledTimezone":null,"userContext":{"__typename":"MessageWorkflowContext","canSubmitForReview":null,"canEdit":false,"canRecall":null,"canSubmitForPublication":null,"canReturnToAuthor":null,"canPublish":null,"canReturnToReview":null,"canSchedule":false}},"moderationData":{"__ref":"ModerationData:moderation_data:340701"},"teaser":"
The F5 Academy Roadshow is rolling into 19 cities (plus two virtual stops), and if you work with apps, APIs, or infrastructure, this event was built for you.
\n\n
","postTime":"2025-04-14T09:49:34.463-07:00","lastPublishTime":"2025-04-17T10:30:41.891-07:00","images":{"__typename":"AssociatedImageConnection","edges":[{"__typename":"AssociatedImageEdge","cursor":"MjUuNHwyLjF8b3wyNXxfTlZffDE","node":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA3MDEtblAzc2RQ?revision=12\"}"}}],"totalCount":1,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3w1fF9OVl98MQ","node":{"__typename":"Tag","id":"tag:announcement","text":"announcement","time":"2021-12-19T07:45:21.000-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":3,"introduction":"","metrics":{"__typename":"MessageMetrics","views":683},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"Conversation:conversation:340701":{"__typename":"Conversation","id":"conversation:340701","solved":false,"topic":{"__ref":"TkbTopicMessage:message:340701"},"lastPostingActivityTime":"2025-05-19T08:28:54.343-07:00","lastPostTime":"2025-05-19T08:28:54.343-07:00","isSubscribed":false},"ModerationData:moderation_data:340701":{"__typename":"ModerationData","id":"moderation_data:340701","status":"APPROVED","rejectReason":null},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA3MDEtblAzc2RQ?revision=12\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/bS0zNDA3MDEtblAzc2RQ?revision=12","title":"Academies.jpg","associationType":"TEASER","width":1130,"height":703,"altText":""},"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMjktRWl0NU5q\"}":{"__typename":"AssociatedImage","url":"https://community.f5.com/t5/s/zihoc95639/images/cmstMjktRWl0NU5q","height":24,"width":21,"mimeType":"image/png"},"Rank:rank:29":{"__typename":"Rank","id":"rank:29","position":6,"name":"MVP","color":"7CC0EB","icon":{"__ref":"AssociatedImage:{\"url\":\"https://community.f5.com/t5/s/zihoc95639/images/cmstMjktRWl0NU5q\"}"},"rankStyle":"FILLED"},"User:user:165464":{"__typename":"User","id":"user:165464","uid":165464,"login":"Kai_Wilke","biography":"My name is Kai Wilke and I'm working as a Principal Consultant for IT-Security at itacs GmbH - a German consulting company specialized in Microsoft Security cloud solutions, F5 customizations as well as for classic IT-Consulting.\r\n\r\nYou can find additional information about me and my work here:\r\nhttps://devcentral.f5.com/articles/q-a-with-itacs-gmbhs-kai-wilke-devcentrals-featured-member-for-february-24890","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2012-03-02T00:00:00.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.f5.com/t5/s/zihoc95639/images/dS0xNjU0NjQtOVhMY2R3?image-coordinates=0%2C0%2C160%2C160"},"rank":{"__ref":"Rank:rank:29"},"entityType":"USER","eventPath":"community:zihoc95639/user:165464"},"ModerationData:moderation_data:305328":{"__typename":"ModerationData","id":"moderation_data:305328","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:305328":{"__typename":"ForumReplyMessage","uid":305328,"id":"message:305328","entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:305246/message:305328","revisionNum":2,"author":{"__ref":"User:user:165464"},"readOnly":false,"repliesCount":1,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumTopicMessage:message:305246"},"conversation":{"__ref":"Conversation:conversation:305246"},"subject":"Re: External Monitor with curl command","moderationData":{"__ref":"ModerationData:moderation_data:305328"},"body":"
Hey Agus12,
\n
an \"External Monitor\" based on external BASH-Scripts is most likely used for rather complex monitoring tasks and should not used for simple monitoring tasks. It would just add unnessecary complexity....
\n
The curl commands your DEVs handed out are looking very simplistic and right now I dont see a good reason to put those CURL commands natively into an external monitoring script. A regular HTTP/HTTPS Monitor with tailordered SEND/RECEIVE strings should be able monitor the availability of your application.
\n
Before helping you to create SEND/RECEIVE strings, you should clarify with your development why they included the -cookie directive and why they enabling the -G option (use GET instead of POST requests) if the -d option uses JSON formated params meant for POST payload. The combination of -G and JSON formated payload results in a slighly broken request URI:
\n
\n
[itacs@kw-f5-dev:Active:Standalone] config # curl -vvv --cookie session_cookie -G -d '{\"request\":\"ping\"}' http://10.0.17.23:81\n* Trying 10.0.17.23...\n* Connected to 10.0.17.23 (10.0.17.23) port 81 (#0)\n> GET /?{\"request\":\"ping\"} HTTP/1.1\n> Host: 10.0.17.23:81\n> User-Agent: curl/7.47.1\n> Accept: */*\n>
\n
\n
Cheers, Kai
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2022-11-29T01:46:31.937-08:00","lastPublishTime":"2022-11-29T02:07:17.232-08:00","metrics":{"__typename":"MessageMetrics","views":706},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXwzfDM5OjF8aW50LDMwNTM1MSwzMDUzNTE","node":{"__ref":"ForumReplyMessage:message:305351"}}]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:305351":{"__typename":"ModerationData","id":"moderation_data:305351","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:305351":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:420123"},"id":"message:305351","entityType":"FORUM_REPLY","eventPath":"category:Forums/community:zihoc95639board:TechnicalForum/message:305246/message:305351","revisionNum":1,"uid":305351,"depth":2,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechnicalForum"},"parent":{"__ref":"ForumReplyMessage:message:305328"},"conversation":{"__ref":"Conversation:conversation:305246"},"subject":"Re: External Monitor with curl command","moderationData":{"__ref":"ModerationData:moderation_data:305351"},"body":"
i will confirm to development why used this curl and is it related cookie on curl command with login,
as i know from the develop they used cookie session to login and will mark API active and server should be up
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"228","kudosSumWeight":0,"repliesCount":0,"postTime":"2022-11-29T06:58:31.027-08:00","lastPublishTime":"2022-11-29T06:58:31.027-08:00","metrics":{"__typename":"MessageMetrics","views":700},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1748534153693","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1748534153693","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1748534153693","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1748534153693","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1748534153693","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1748534153693","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1748534153693","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1748534153693","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1748534153693","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1748534153693","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListMenu-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListMenu-1748534153693","value":{"postTimeAsc":"Oldest","postTimeDesc":"Newest","kudosSumWeightAsc":"Least Liked","kudosSumWeightDesc":"Most Liked","sortTitle":"Sort By","sortedBy.item":" { itemName, select, postTimeAsc {Oldest} postTimeDesc {Newest} kudosSumWeightAsc {Least Liked} kudosSumWeightDesc {Most Liked} other {}}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1748534153693","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1748534153693","value":{"loadMore":"Show More"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewCard-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewCard-1748534153693","value":{"gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1748534153693","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1748534153693","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1748534153693","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1748534153693","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/common/ExternalLinkWarningModal-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/common/ExternalLinkWarningModal-1748534153693","value":{"title":"Leaving the Community","description":"You're about to leave this site and navigate to an external domain. Are you sure you want to continue?","action.submit":"Continue","action.cancel":"Go Back"},"localOverride":false},"CachedAsset:text:en_US-components/attachments/AttachmentView/AttachmentViewChip-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/attachments/AttachmentView/AttachmentViewChip-1748534153693","value":{"errorTitle":"Failed!","previewFile":"Preview File","downloadFile":"Download File {name}","removeFile":"Remove File {name}","errorBadExtension":"This file does not have a valid extension. \"{extensions}\" are the valid extensions.","errorFileEmpty":"This file is empty or does not exist.","errorTooLarge":"The maximum file size is: {maxFileSize}.","errorTooMany":"Too many attachments. The maximum number of attachments per message is: {maxAttachmentCount, number, integer}.","errorDuplicate":"This file is already attached."},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1748534153693","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1748534153693":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1748534153693","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"technicalforum","messageSubject":"external-monitor-with-curl-command","messageId":"305246"},"buildId":"WUNImik7DwO6HIAcnSEUX","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"f5","serviceVersion":"25.4.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_seo_QAPageSchema","components_customComponent_CustomComponent","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_messages_TopicWithThreadedReplyListWidget","components_featured_content_FeaturedContentWidget","components_messages_MessageListForNodeByRecentActivityWidget","components_messages_RelatedContentWidget","components_messages_MessageView_MessageViewStandard","components_messages_ThreadedReplyList","components_customComponent_CustomComponentContent_TemplateContent","components_messages_EscalatedMessageBanner","shared_client_components_common_List_UnstyledList","components_messages_MessageView","shared_client_components_common_Pager_PagerLoadMore","shared_client_components_common_List_GridList","components_messages_MessageView_MessageViewCard","components_messages_MessageView_MessageViewInline","components_customComponent_CustomComponentContent_HtmlContent","shared_client_components_common_List_UnwrappedList","components_attachments_AttachmentView","components_attachments_AttachmentView_AttachmentViewChip","components_tags_TagView","components_tags_TagView_TagViewChip","components_customComponent_CustomComponentContent_CustomComponentScripts"],"appGip":true,"scriptLoader":[]}
