Satoshino's avatar
Satoshino
Icon for Cirrus rankCirrus
Sep 11, 2023
explanation about tmm usage
Hi Folks!
i need a clarification about tmm usage on BIG-IP appliances.
i have a guest hosted by a VIPRION (C2400), with 4 assigned cores and an high CPU utilization.
During my investigation i found out that connections use only 2 tmm processes: (slot/tmm: 1/1) and (slot/tmm: 1/0), so only tmm processes assigned to core 0.
Those tmm process have the same amount of connection but i don't understand why it doesn't use tmm processes assigned to core number 2, shouldn't it use them equally?
I undestood that core 0 and 2 are assigned for data plane, and that every core has two tmm processes, the first is the main process while the second is used only during spikes of traffic, am i right?
here some commands output:
Sys::TMM: 1.0
Global
TMM Process Id 10670
Running TMM Id 0
TMM Count 1
CPU Id 0
Memory (bytes)
Total 9.2G
Used 569.9M
CPU Usage Ratio (%)
Last 5 Seconds 28
Last 1 Minute 28
Last 5 Minutes 28
Sys::TMM: 1.2
Global
Running TMM Id 2
TMM Count 1
CPU Id 2
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 59
Last 1 Minute 59
Last 5 Minutes 59
Sys::TMM: 1.0
TMM Traffic ClientSide ServerSide
Bits In 4.5P 4.4P
Bits Out 139.5T 120.3T
Packets In 482.5G 411.1G
Packets Out 259.2G 295.3G
Current Connections 19.8K 21.6K
Maximum Connections 129.2K 131.0K
Evicted Connections 0 0
Slow Connections Killed 0 0
Total Connections 17.6G 17.6G
Total Requests 353.4M -
Errors
Maintenance Mode 0
Virtual Addr Limit 0
Virtual Server Limit 0
Wrong Address 0
No handler 2.7M
No Staged Handler 0
No license 0
Connection Memory 0
Packets Dropped 4
Packets In Errors 0
Packets Out Errors 0
Connections Redirected 0
Sys::TMM: 1.2
Bits In 3.4P 3.2P
Bits Out 342.6T 109.9T
Packets In 487.9G 337.4G
Packets Out 354.5G 214.0G
Current Connections 19.7K 20.9K
Maximum Connections 129.4K 130.6K
Total Connections 27.3G 27.3G
Total Requests 325.0M -
Errors
Maintenance Mode 0
Wrong Address 0
No handler 7.0M
No Staged Handler 0
No license 0
Connection Memory 0
Packets Dropped 0
Packets In Errors 0
thank you
  • Hi Satoshino ,
    first you need to read about Hyper threading feature in F5 :
    https://my.f5.com/manage/s/article/K23505424
    https://my.f5.com/manage/s/article/K15003
    then >> your guest runs over 2 cores devided into 4 hyper-threads based on vCPU that you have assigned  while configuring this guest.
    I see slot 1 >> ( tmm1.0 & tmm1.2 ) you can imagine it as ( tmm0.0 & tmm0.2) based on the slots.
    > For traffic I see traffic is balanced over the two tmm instances without issues.
    your question : I undestood that core 0 and 2 are assigned for data plane, and that every core has two tmm processes, the first is the main process while the second is used only during spikes of traffic, am i right?
    > Not exactly right , you need to consider hyper-thread design , and know how it works then you can understand this mechanism.
