Technical Forum
Custom Alert Banner
except ip from asm logging
kimhenriksen
Is it possbile to except one or more IPs from the ASM log? Is should still block and do everything.. but just not log anything from that IP.
1 ACCEPTED SOLUTION
Hello,
you can accomplish this by using IP address exception as the below config:
https://techdocs.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-implementations-13-1-0/9.ht...
Thanks,
2 REPLIES 2
Hello,
Thanks,
Thank you!
